Off road diesel
   / Off road diesel #1
keving
Virginia/WV
Kubota 7040HDC
Just wondering if there is any negative issues utilizing the tax free diesel. The warning on the pump says that it could have sulpher greater than 500ppm. Obviously the upside is the 70 cents per gallon savings. But if the downside is engine issues...forget it!
BTW, the diesel is for my new 5030 HSTC. I have right about 20 fun working hours on it and can't wait to put more!!!
I appreciate your input,
KG
   / Off road diesel #2
More frequent oil changes.
enjoy the money.
Bob
   / Off road diesel #3
I use it ALL the time in my L48. NO problem...........even in my off road truck.
more oil changes????
   / Off road diesel #4
monkeymonk said:
...more oil changes????
That's right. More sulfur in the fuel means more sulfuric acid in your crankcase.
   / Off road diesel #5
KG
If there were any major problems, every farmer of an size wouldn't be using it. Go ahead and use it.
   / Off road diesel #6
In another couple of months it won't make a bit of difference anyway. LSD or S500 or fuel with >500 ppm of sulphur is going the same way as the dinosaurs. It will be disappearing. :( Since today the big refineries cannot by law make it any more only the small refineries will be making it. This means supply will be extremely limited for the next 2 years when it will be discontinued altogether. I would expect the price to increase accordingly, even without the federal tax.
Everyone will be using ULSD. That's a fact and everyone better start to realize it. Older machinery should be using an additive to insure proper lubrication.
California residents have no choice. As of September 1 you can only buy ULSD.
   / Off road diesel #7
MadReferee said:
In another couple of months it won't make a bit of difference anyway. LSD or S500 or fuel with >500 ppm of sulphur is going the same way as the dinosaurs. I will be disappearing.
Say it ain't so. We like having you around here.
   / Off road diesel #8
Thank goodness for the edit function.:eek: :eek: :D :D
2022 BRAZ0 40FT PIT BOSS BELLY DUMP TRAILER (A54607)
2022 BRAZ0 40FT...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2018 Link-Belt LBX 300X4 Hydraulic Excavator - Aux Hydraulics - 6388 Hours Showing - 24 In Bucket (A55218)
2018 Link-Belt LBX...
1990 Ingersoll Rand 185 Towable Diesel Air Compressor (A52377)
1990 Ingersoll...
2012 UNVERFERTH 6-INCH FRONT WHEEL SPACER KIT FOR 10 BOLT HUB (A55301)
2012 UNVERFERTH...
2015 CHEVROLET SILVERADO CREW CAB TRUCK (A51406)
2015 CHEVROLET...
