Off road diesel
   / Off road diesel #1
tractortroof
Jacksonville
kubota b2650
I’m wondering if I filled up my 100 gallon tank with bad diesel. This was filled up 7 months ago and the backhoe fuel filter/separator just clogged up with like brown gunk. I changed it and it worked fine.
How do I check the fuel in the transfer tank? Any additives that I should add?
   / Off road diesel #2
Drain some fuel from the transfer tank unfiltered into a large glass jar and look at it. You'll be able to see any water, algae, gunk, etc. pretty easily.
   / Off road diesel #3
Brown gunk is microbial algae. Bad Ju Ju. I'd dose your fuel with Powerservice Bio-Kleen according to the bottle instructions. I use it religiously all the time. Been down the algae road and it can be expensive to fix.
   / Off road diesel #4
Are you using bio-diesel or a bio-diesel mix? That is a lot more susceptible to microbial growth.
Is your tank outside in the heat and cold where condensation can form inside the tank?
   / Off road diesel #5
As mentioned a Biocide added to the fuel,
and I would add a filter to the outlet of the tank (pump).
After adding the biocide I would run the pump circulating the fuel in the tank to get it blended well.
Then have some spare filters as the dead algae will pump up your filters.
I did clean up a storage tank one time that got infested, after treating it with a biocide twice I started ciculating it in the tank using the dispensing pump it took several filters to get it cleaned up.
Now I routinely add a biocide at every fill up, just as a preventive measure.
   / Off road diesel #7
Another user of biocide. Many people scoff at using additives but if they prevent even one issue, they are worth it to me.
I was down with bad fuel and clogged fuel lines a few years ago, when getting ready for winter and didn’t really need the aggravation.
It took me a couple of weeks to figure out what was wrong.
Biocide is cheap insurance.
   / Off road diesel #8
Between biocide in my diesel and Blue Marine Stabil, I've been issue free for a couple years now. I also quit using B20 as well.
BLAST SHIELD (A50854)
2013 GMC Terrain SLE SUV (A50324)
2013 GMC Terrain...
2008 24ft. Haulmark Edge T/A Enclosed Trailer (A49461)
2008 24ft...
KUBOTA RTV X1100C UTV (A51406)
KUBOTA RTV X1100C...
1984 NAVISTAR 1954 CABLE HOIST (A51222)
1984 NAVISTAR 1954...
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A51222)
2017 FREIGHTLINER...
