ForestGrump
I have an off grid battery backup system with two battery banks one is 370ah and the other is 225ah..
I have acquired another set of batteries 3 years old that were left discharged (J185H-AC 225ah) and I'm working on reviving them to add capacity
My current battery banks have an amp/hr rating of 370ah and the other has a rating of 225ah. Both battery banks are parallel except when servicing.
My question is this;
When setting up the charging rate which is programmable do I use the combined ah rating of 595ah or the highest of the group which in this case is 370ah?
When I charge the banks separately I use the individual battery ah rating.
90cummins
Ok I'm confused. I used to have 3 J185H's so I am familiar with your situation. Your use of the word servicing I don't understand and you never state what type or size of charger you use.
Soooo, each battery bank should be made up with the same battery, same age, type, size etc. Service is usually used in the sense of the battery being in use.
Batteries when hooked in parallel have the same voltage but their amperage are additive. In series the voltages are additive and the amperage is the same, therefore the need for the same battery. Two 6v 360 Ah in series are 12v at 360Ah. Hooked in parallel they are 6v at 720Ah - good enough to start my old VW bug.
The J185's are big batteries - Ah and the charger must also be of sufficient amperage to do the job in a reasonable amount of time.
You now have 3 banks - close to 1000Ah. Charging in parallel is 12v at 1000Ah. Charging in series is 36v at the greatest amperage which is a mess.
A discharged battery on a modern smart charger will try to give as many amps as possible at a specific voltage till the 90 to 95% recharge is reached. Then it will go into the second cycle where a preprogrammed voltage is forced into the battery - for most Trojans this would be 14.8 volts till close to 100% is reached then to float. Too many amps and too many volts you go boom. Solar charge controllers will have a temperature sensor to keep the boom factor and battery temperature to a minimum.
A 150A charger on an 18Ah battery - boom.
A 10A charger on a 500Ah battery bank, go fishing. Speaking of which go to Bass Pro's website and look at their battery chargers. You will see single, double and triple bank chargers at different amperages. Bass fishermen like batteries and battery banks and they want them ready for the next day.
To insure longevity do not mix batteries in a bank. Charge each bank separately. Each battery has a mind of its own and it wants to retire to battery heaven. Keep the batteries desulfonated.
