# of zerks on 3710
   / # of zerks on 3710 #1
Joesgoats
Mass
Grand L 3710HST
My manual states there should be 9 grease fittings on my L3710. I could only find 7. They said 2 on the knuckle, I found 1. It said 2 on the axle support, found 2. Said 2 on the power steering pump, I found 1.
Any idea where the missing ones are?
   / # of zerks on 3710 #2
My manual shows 2 fittings on top link of 3ph, 2 fittings on right hand lifting rod of 3ph, 1 fitting on top link bracket of 3ph, 2 fittings on power steering cylinder, and 2 fittings on wheel knuckles of 2wd 3710's. My manual says nothing of axle support zerks.
DaveH
Dave,
That is what my manual says as well. I have 4wd so the fittings are slightly different. But I can only find one zerk for the power steering. There are two fittings in the area where the axle sits, one in front and one behind (I called those axle supports). The rear fittings are the same. So there are 5 in the rear, and should be 4 in front for 4wd. I definitely could only find one for the power steering. Are some well concealed?
Joe
Panorama 8 Wheel Rake (A50515)
Panorama 8 Wheel...
New Swict 66" Skidloader Bucket (A50774)
New Swict 66"...
2020 Cadillac Escalade 4x4 SUV (A50324)
2020 Cadillac...
2004 Caterpillar 345B Hydraulic Excavator (A50322)
2004 Caterpillar...
AGT SSFM81 Drum Mulcher Attachment (A50322)
AGT SSFM81 Drum...
Case IH 1250 Grinder Mixer (A50515)
Case IH 1250...
