OEM Filter Part Number
   / OEM Filter Part Number #1
BeeFarmer
S.E. Ohio
TC 33D
Does anyone have the OEM part numbers for all the filters for a TC33D? If you would be able to post the number it would be appreciated...
Many Thanks and Seasons Greetings!
   / OEM Filter Part Number #2
Here's the ones for my '03 33D. You'll notice that there's two numbers listed for the Hydrostatic. According to my dealer they're interchangable.
Fuel Filter SBA360720020
Hydrostatic SBA340500720
Alt Hydrostatic SBA340500930
Hydraulic Oil SBA340500890
Engine Oil SBA140517020
Outer Air Filter 86549700
Inner Air Filter 86549701
134 Hyd Oil 2.5 gal 9624450
Thanks David, what I was trying to do was to match up those numbers with Wix Filters. The only one that didn't show up was Hydraulic Oil SBA340500890. I was doing some double checking as I had some issues with my JD tractor part numbers and the Wix filter locater.
Thanks again, I wonder if anyone is using the Wix filters. I went to the New Holland Dealer the other day and forgot to ask the numbers and I know today they were closed. BTW the dealer was using Fleetguard filters for the replacements.. that was interesting.
   / OEM Filter Part Number #4
I did the same thing. Here's the list I have
<ul type="square">
[*] Description---NH Part Number----Wix PN
[*] Fuel Filter----SBA360720020-----33264
[*] Hydrostatic---SBA340500720-----57098
[*] Hydrostatic---SBA340500930-----57098
[*] Hydraulic Oil---SBA340500890----No Cross
[*] Engine Oil-----SBA140517020-----51056
[*] Outer Air------86549700---------46438
[*] Inner Air------86549701---------42985
[/list]
I contacted Wix and gave them all the information on the Hydraulic oil filter and they are looking into a replacement for that one as well. Maybe if a few more folks were to contact them they'd see an interest and it might help roll things along.
   / OEM Filter Part Number #5
Hum... No easy cross reference for the hydrostatic filter, and I wonder which of the OEM P/Ns is (generally by far) the most expensive?
Funny how things work that way...
   / OEM Filter Part Number #6
Part # SBA340500890 was previously SBA340500370, SBA340500371, OR SBA340500770 New Holland frequently changes part numbers to stay ahead of the after market companies cross referencing. One of the above numbers should cross reference for you.
   / OEM Filter Part Number #7
Here's what the Wix web site gives for the hydraulic fluid filter if you drill down by equipment type/make/model:
Off-Highway Equipment
NEW HOLLAND
TC33D
Air Filter 42985 TC33D w/All (Inner)
Air Filter 46438 TC33D w/All (Outer)
Fuel Filter 33264 TC33D w/All
Hydraulic 57098 TC33D w/All
Oil Filter 51056 TC33D w/All
I received a message from Filter1 that basically says not to rely on the drill down but to go by the OEM manufacture part number
The 51056 I received appears to be smaller than what is on there currently. Anyone have any thoughts on this?
2012 Jeep Grand Cherokee SUV (A56859)
2012 Jeep Grand...
KENWORTH T/A DAY CAB ROAD TRACTOR (A57192)
KENWORTH T/A DAY...
TANK MANIFOLD (A58214)
2012 Freightliner M2 106 Altec TA37M 37ft Insulated Material Handling Bucket Truck (A55973)
2012 Freightliner...
2019 CATERPILLAR 305E2 CR EXCAVATOR (A52709)
2019 CATERPILLAR...
2024 Yakta YXR120 Zero Turn Lawnmower (A57453)
2024 Yakta YXR120...
