Oder Briggs starter
/ Oder Briggs starter #1
twostroke91
70's Bolens G9 855
Can someone please tell me how to get the brushes back in my starter . there are no holes ar any way i can figure out how to hold them in place while putting the end plate back on and putting the rotor into it . Please help it's getting the best of me and i have to keep chasing the springs all over .
Thank's in advance .
Don
/ Oder Briggs starter #2
Is this one of those starters with the pie shaped brushes that go in from the end instead of the side? If so I made a sheet metal "fork" that would hold them into the brush holders while I gently slide the end plate over the shaft. Having the armature up just a little helped as well.
Thank's for the reply . The starter has 4 reg brushes that come in from the side of the end plate . I did however get it back together . I should have made a video of of it but didn't think about it till i was done . To make it short , I used paper clips , bent pieces of them into a staple looking shape that would hold the brush's back and hook over the outside of the end plate therefore having both hand's free . I then just put the shaft in and pulled the holders out and finished the assembly , worked real well , any wire stiff enough to bend into the shape and hold the spring's back will work . Maybe this will help someone else out .
Don
2010 CONQUEST TRAVEL TRAILER (A63569)
2010 CONQUEST...
Heavy Duty Booster Cables (A59230)
Heavy Duty Booster...
2004 VOLVO VHD TRI/A CEMENT MIXER TRUCK (A59911)
2004 VOLVO VHD...
New Holland 565 Square Baler (A64047)
New Holland 565...
2011 CLARK OIL FIELD FLOAT (A63569)
2011 CLARK OIL...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
