Odd problem-Navigation slows down
   / Odd problem-Navigation slows down #1
BB_TX
Veteran Member
Home-1+ acres New Hope, TX / 24 acres-Fannin Count
JD 950
When I log in to TBN, everything loads very fast. But after moving between different TBN forums and threads for a while, suddenly the load speed drops to VERY slow. I can leave TBN to other web sites for a while, come back, and everything is fast again. Or I can close my browser and reopen it and everything is OK again. For a while. Then it slows down again. And this is only when I am in TBN. No other web site I visit does that. Any ideas? :confused:
   / Odd problem-Navigation slows down #2
From time to time (last night for example) I have noticed the same thing.
   / Odd problem-Navigation slows down #3
I'll join that club. It'll be going along great and suddenly it's dead.:confused: Sometimes hitting the stop download button and re-clicking the link works for me, sometimes I just give up in frustration.
   / Odd problem-Navigation slows down #4
We can't identify any problems with our server. And you will find that if you look at the page generation times at the bottom of the screen, even when a page "hangs" when loading, the times will be good (under 1 second). This means that as soon as your computer connects to our server, the request is processed quickly.
However, we all have been having similar problems with websites other than TBN. It started a couple weeks ago. So, there's a chance that there are routing issues somewhere online, and those issues affect many hosts.
That said, we have our server admin looking into it, too.
Thanks for the reply Mohammad. It just seems odd that only TBN does this on my PC. Pages will load very fast thru multiple forums, threads, and posts. Then suddenly, bang, it just stops or at least slows down a LOT. Sometimes the page goes blank and appears to be doing nothing. Sometimes I get the TBN banner at the top but nothing below it. Sometimes it will eventually load. Once or twice I let it go long enough to get the error message "site not found". I can go to any other web site I visit (which is a lot) and they are fine no matter how long I stay there. Eventually I come back to TBN and it is fine again, for a while. Then the same problem reappears. May be something about my PC. Don't know.
   / Odd problem-Navigation slows down #6
As an interim solution, if a page doesn't load normally when you click, simply click the link again. It should load normally on the second click.
Thanks, Mohammad. I tried that also. I tried clicking stop and reclicking. I tried going all the way back to the TBN home page. I tried different TBN forums. Same thing. Sometimes I see the progress bar at the bottom creaping across. Sometimes no sign of any thing happening. But if I click on any other web site, that site loads immediately. I come back to TBN later and all is well again. For a while. Really odd. Just started doing this a month or so ago. Maybe whatever it is will go away as suddenly as it came.
   / Odd problem-Navigation slows down #8
Exactly the same problem happens to me, works fine then just stops loading.
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
2022 Case IH Magnum 340 AFS MFWD Tractor (A53342)
2022 Case IH...
2012 Ford F-250 Pickup Truck (A51692)
2012 Ford F-250...
2019 RAM CUTAWAY SERVICE BODY TRUCK (A52577)
2019 RAM CUTAWAY...
2018 Vermeer Chipper (A51573)
2018 Vermeer...
2019 HYUNDAI HX300L EXCAVATOR (A51246)
2019 HYUNDAI...
