Odd Parts Machine
/ Odd Parts Machine #21
No problem, really. Plan to weld them all together and make a stretch mower.......great for long, flat, straight yards.
Mark
/ Odd Parts Machine
Sunday project. Needed to move some cleachie to leval yard. Used 10" I beam, halve truck springs, 3/4"and 5/16" rod, some pipe and plate.
/ Odd Parts Machine
A side view showing manual linkage.
/ Odd Parts Machine
Here's a shot of a David Bradly turning plow reworked to 3ph. I have been using this several years to break up the cleachie for leaveling and trenches.
/ Odd Parts Machine #25
</font><font color="blue" class="small">( Here's a shot of a David Bradly turning plow reworked to 3ph. I have been using this several years to break up the cleachie for leaveling and trenches. )</font>
OK, I admit I have no idea what "Cleachie" is. Still, you are cleaver at using the materials at hand to do the work you need to do.
/ Odd Parts Machine #26
cleachie ????
Like the plow.
When I was young, my job was to shovel the snow in our drive.
I decided that a plow was 'de rigeur', so I took a 3/4" ply (about 16" X 60", I guess) added vertically 2 pcs of 2 x 4 X 16" lined up with the bumper over riders on my old VW beetle, extended short 2 x 8 from the 2 x 4's that butted onto the bumper inside of the overriders.
The 2 x 8's were curve cut to match the bumper.
I attached 2 flat steel 'hooks' that sort of clipped onto the backside of the bumper.
A length of bed spring angle well bolted made up my 'cutting edge'.
A 3" piece of hockey stick bolted vertically on the left side with a suitable length of rope was the lifting mechanism.
Problem was that I had to drive with the driver's window open to operate the 'lift' LOL.
In actual fact, that simple 'kiss' plow really did a remarkable job.
I plowed up to 10" snow falls from our 7-800 ft drive that whole winter! With a plywood plow!
But then the old beetles (with snow tires) were virtual tractors as all the weight was over the wheels.
/ Odd Parts Machine
It worked well, moved about 3yds before 2 welds broke loose from the springs. Forgot springs are tempered and brittle. Oh, well time for 3/8 plate.
/ Odd Parts Machine
Cleachie, even if spelled wrong, it what gravel around here are made of. It happens that my yard is comprized of this in it's natural state with some soil. Very little soil.
/ Odd Parts Machine #29
Cleatus on your blad on the I beam in the bottom cornerof the blade to make spreading and grading easier try mounding a peic of 1/4 to 3/ths by 2 flat bar on an ange from the bottom of the flange on you Ibeam blade. to the web. It will help peel and roll the material like a big dozer. I had a smalljob onecewhere the busness owner had a small walkway /alley between 2 stores. They had a commonroof theouh. To lay down the stoen Id haul it in from the street in a homemade dump cart behind a garden tractor down a the 36 inchwide alley then I made a blade similar to yours but i made my blade with a cutting edge like I described. Took all day but faster and cooler than the alternative.
/ Odd Parts Machine
Taylor I had been thinking the same thing. Also in the above explanation of cleachie, I ment to say it's what gravel roads are made of.
/ Odd Parts Machine #31
One of my first welding projects when I was 14 was to buld a blade for a 5 hp Dynamark. I t was like that but i ripped the transmission to peices in it after about 2 months of hard dozing lol . not to mention I had changed the pulley ratios to a super low gear. Too much torque lol. It made the counter shaft in the peerless chaindrive clim onegear on top of the other. THe chaindrive had also been modified to 2 sets of 350 Chevy timing chains and the aluminum housing was the weak spot. Here cleachie is often called chert, clay gravel, and caliche. depends on what part of the county your from.
/ Odd Parts Machine
It's back together and working well. it might even do better if I were to add some kind of teeth, any ideas.
/ Odd Parts Machine #33
Cleatus you could make some back drag rippers or put some small teeth on the bottom of the cutting edge. I workedfor a company that had a Cat 12g grader with Jagz on the cutting edge they were carbide tipped cones they were a big asset ingradingthegravel roads here after they sunbake after a hard rain and traffic.
Tires and Rims (A65640)
Tires and Rims...
2009 Ford LCF Box Truck (A66285)
2009 Ford LCF Box...
2018 JOHN DEERE 650K LGP CRAWLER DOZER (A64279)
2018 JOHN DEERE...
Western 8.5 Pro Plus Ultra Mount (A62679)
Western 8.5 Pro...
New/Unused CFG Industrial H12R Mini Excavator (A65579)
New/Unused CFG...
2016 P.J. Deck Over Trailer, VIN # 4P5F82028G1250354 (A65563)
2016 P.J. Deck...
