3-Point Hitch odd behavior of 3pt today...
   / odd behavior of 3pt today... #1
MossflowerWoods
Super Member
Fredericksburg, VA
Kioti DK50SE HST w/FEL, Gravely 60" ZTR Mower. Stihl MS290 (selling), CS261, & FS190 + Echo CS400 & 2010 F-350 6.4 PSD snowplow truck
Guys,
It has been a while, but I'm not a n00b as I used to be, but today something odd happened.
I was dropping the stump grinder and switching to bush-hog, and the 3pt lever would NOT lower the grinder until I lowered the DRAFT lever? The draft lever has never really done anything for me, and now it is preventing lowering, and actually raising the 3pt?????
What am I forgetting or doing wrong?
Thanks in advance!
Be well,
David
   / odd behavior of 3pt today... #2
There is a nob just under the drivers seat, it adjust the lowering speed. If it's set too far it won't lower the 3pt. It's easy to knock and therefore stop the three point lowering check it out.
   / odd behavior of 3pt today... #3
Hi David, good to see you again. Yes turn the knob under the front of the seat rail counterclockwise until the implement falls to earth. Adjust to your taste for drop speed each individual weight..
   / odd behavior of 3pt today... #4
On my tractors, if I put the draft control lever up the three point arms will not drop all the way. It's always been that way and I get draft control on everything.
   / odd behavior of 3pt today... #5
I think KiotiJason and James (KOua) have you covered. The knob under my seat has been vibrating itself to the slow(off) side of the house on occasion lately. A couple of turns and we're back in business!
Guys,
So I know about the silver knob. That was a panic attack a couple years ago and TBNers responded faster than my dealer!
My big concern is this is DIFFERENT than it has been the last 160 hours of operation.
I need to do some more bush hogging so I will play with all the components some more, but I seem to recall the draft had no effect on my 3pt at all, and now I cannot lower the 3pt without lowering the draft (plus after messing with silver knob it drops super fast).
Lots of crazy changes going on in my life, Divorce finalized last month, clear-cut logging started last week, too many things to list...
Be well all my good friends!
David
   / odd behavior of 3pt today... #7
What isn't the same? Is it possible you had the draft control lever all the way down in the past and left it that way? In that case, your lift arms would raise and lower without interference or obstruction.
Should you begin to raise the draft control lever, there is a relationship between that draft control and your position control lever that could cause the lift arms to stop in the middle or, if you had the draft lever all or most of the way up, prevent any movement in the arms. I have installed draft control on a couple of tractors and the installation process requires adjustment and you go though the process of adjusting the lever until the arms stop and then backing off a little.
I would try lowering the draft control lever all the way and leave it there. See if that returns things to what you recall. If things are still not what you remember, I would guess the draft control lever needs an adjustment but don't go there just yet. It's not likely to need adjustment. Advise what you find and welcome back to putting some hours on the tractor.
   / odd behavior of 3pt today... #8
Correct. Draft control is meant to lift the 3pt depending on the pressures against the top link (each of the three holes the top link can go in on the back of the tractor provide different levels of draft sensitivity)...
When using ground engaging equipment like a plow, you adjust the draft control up so the plow won't run too deep and bog or stall the tractor.
Anytime draft isn't being used (mowing, post hole digging, FEL work), the control should be all the way forward/down and not be moved. With it down all the way, the position control will react as expected.
Good points...
I've not run anything off the 3pt for some time and it is most likely to be operator error.
Hmmm....
Be well,
David
   / odd behavior of 3pt today... #10
Well, check it out and advise.
UNUSED AGT MXMRW14 STAND ON WHEELED SKID STEER (A51243)
UNUSED AGT MXMRW14...
2019 CATERPILLAR 440 BACKHOE (A51242)
2019 CATERPILLAR...
2015 VOLVO VNL TANDEM AXLE DAY CAB (A52141)
2015 VOLVO VNL...
2016 CATERPILLAR 336FL EXCAVATOR (A51242)
2016 CATERPILLAR...
(4) Texas Built 25' Stand Alone Panels (A50515)
(4) Texas Built...
2006 INTERNATIONAL 7600 T/A DUMP TRUCK (A51406)
2006 INTERNATIONAL...
