O what to do... Some advice please
   / O what to do... Some advice please #1
ethiojazz
Ashton, MD
Kubota B2410, Kubota ZD 326, Kioti DK35SE HST
So now that we have had two of the most impressive (and not in the most attractive way) snow storms here in the Mid Atlantic, I am again faced with decisions to be made... My B2410 has served me well but is definitely showing its inadequacies. So the dilemma is between going out and getting a skid steer (used probably - Something with about 1000 hours or less) or upgrade to a GL series.. Maybe an 4240 or 3540. Options I hope others have dealt with and hoping to learn...
My uses have expanded a bit... Still maintaining about 4 acre orchard, starting an organic veg on about 2 acres and still need to clean/clear about 5 acres of woods with lots of "garbage" undergrowth and limbs, dead trees etc,,, Finally based on last weeks events plowing the 300 foot plus driveway plus maintain a 200 foot plus gravel driveway to the shop..
Suggestions?
   / O what to do... Some advice please #2
Suggestions?
To me the tasks you describe seem better suited to a tractor than a skid steer.
   / O what to do... Some advice please #3
I was in your same position and I took a huge chance and switched to skid steer. I iwll never look back. The skid steer is so much more versatile than a tractor. Best way to explain it is it's the Victorinox of the tractor world.
What I love about it it's a one man machine. In a typical day I will switch to one of several attachments and never leave the cab, I just pull up and throw a switch and it locks in pull up again, throe a switch and it releases and I hook up to attachment two.
The only time I get out is to connect doses if needed. I went with tracks and I no longer have flats ahhhhhhhhh. Flats were killing me with the tractor.
The lift capacity is amazing with a skid steer. Clean up with a grapple and a front mounted grader for the drive and take your pick on buckets is all you need.
Whistlepig... Not that I would admit to it but it seemed that I was renting a skid steer for things you would associate with a tractor. The tiller with a tractor is pretty good... I borrowed a neighbors to try it... But in the end I rented a bobcat with a tiller and it really out worked the tractor for sure. I could put significant downward pressure to dislodge clumped up clay. and then go over it lightly and leave a perfect bed.
Cat Driver... I am actually ok with the implement changes as I am not commercial user but I will certainly say.. we use a skid to auger the tree holes... used it to clean the brush piles... to grade the gravel driveway... I am just wondering if the trend will continue...
RYOBI 2900 PSI GAS PRESSURE WASHER (A51248)
RYOBI 2900 PSI GAS...
UNUSED CFG QUICK ATTACH HYD POST DRIVER (A51248)
UNUSED CFG QUICK...
2017 Polaris 500 Ranger Diesel Utility Cart (A50324)
2017 Polaris 500...
Hay Van FL-95 Bale Squeezer - Hydraulic Bale Grab for Round and Square Hay Bales (A53472)
Hay Van FL-95 Bale...
2021 JOHN DEERE 8R340 LOT IDENTIFIER 194 (A53084)
2021 JOHN DEERE...
JOHN DEERE LOT IDENTIFIER 112 (A53084)
JOHN DEERE LOT...
