Loader O-rings
   / O-rings #1
mgbk1200rs
wells,me
Ford 1900
Hello, I have a ford 1900 tractor 4x4. There will be lots of questions, But not all at once, The major problem is cleaning etc, I have a few leaks in the loader controls, are they hard or easy to repair? Yes, that is a dumb question, we own british cars I can rebuild SU carbs, heads, do tune ups, adjust valves, and all the MG type problems. The major questions, are the o-ring metric or standard, is there a kit I would need to order, Yes we have an owners manual,shop manual and a parts catalog. But a little help increases my confidence and save me money. Thanks Mike
   / O-rings #2
Mike, the valve is real simple. If you have the valve pictured in the illustration and it is mounted horizontally, then you can order the orings pictured in the illustration, #6, but they run about $38. The orings are standard, not metric, will run about $2. at a hydraulic shop or well stocked auto parts store. The liader is a 771 if it is from Ford. Not much to it.
The tractor is pretty straight forward and not hard to work on if you have the sefvice manual.
4- 6 DRILL COLLARS (A50854)
4- 6 DRILL COLLARS...
2024 New Holland T8.410 MFWD Tractor (A51039)
2024 New Holland...
2013 Mack GU713 T/A VacCon Combination Sewer Jetter Vacuum Truck (A50323)
2013 Mack GU713...
2021 Ford F-250 4x4 Ext. Cab Pickup Truck (A49461)
2021 Ford F-250...
2014 PETERSON 4700B HORIZONTAL GRINDER (A51242)
2014 PETERSON...
2015 DODGE RAM...
