O-rings on hyd. screen - GC2300
   / O-rings on hyd. screen - GC2300 #1
44trxfun
western NY
MF GC2300
I'm getting ready to change my hydraulic fluid in the GC2300 and wanted to have an O-ring or two on hand in case either or both of the ones on the screen need replaced. My dealer can't tell me what size the O-rings are; can any of you GC2300 owners?
Thanks!
   / O-rings on hyd. screen - GC2300 #2
Just a note. If you need an o-ring, it would be a very rare thing.
Chances may be slim, but I still wouldn't mind having an extra on hand. Anyone know what size? Thanks.
   / O-rings on hyd. screen - GC2300 #4
i would change all o-rings that dont require extra work to get to.
   / O-rings on hyd. screen - GC2300 #5
44trxfun,
It is difficult for me to understand why your dealer can't find a part number for an o-ring. The dealer should be able to pull any part to your tractor up on a computer. Unbelievable !!!
BER
   / O-rings on hyd. screen - GC2300 #6
44,
If your GC2300's spin on filter is on the suction side, you may not have a screen to have a o-ring on.
   / O-rings on hyd. screen - GC2300 #7
44trxfun- I agree with Jerry, unless you somehow damage the o-ring when you remove the screen there is not much to go wrong with it. I just changed the oil in my 1240 and the screen O-ring is simply a static seal, no movement to cause wear. Sometimes there is more risk in trying to do things too good.
   / O-rings on hyd. screen - GC2300 #8
You shouldn't need to replace the o-ring for many years. The dealer can order the o-ring for you. If you don't want to buy one from the dealer, you can measure it yourself when you change the filter and pick one up locally for a spare. It might be difficult though because they are metric.
   / O-rings on hyd. screen - GC2300 #9
.... <font color="blue"> If it ain't broke, take it apart anyway </font>.
Syncro
That's what he's trying to do but he can't get the dealer or anyone else to tell him the part number for the O-ring.
Shulte XH-1500 (A50121)
Shulte XH-1500...
PT Double Drum Pasture Aerator (A50120)
PT Double Drum...
Woods 3 PT Blade (A52349)
Woods 3 PT Blade...
DOOSAN G70 PORTABLE GENERATOR (A52472)
DOOSAN G70...
2012 UNVERFERTH 15-INCH REAR SPACERS FOR 10 BOLT HUB (A52748)
2012 UNVERFERTH...
