o rings for new holland tc30 injector pump
   / o rings for new holland tc30 injector pump #1
red5950
chesterfield nj
new holland tc30
i am trying to find the orings for a tc30 injector pump they are not perfectly round flat on inside and outside.. the one fits a groove of .747 and the other .787 they are approximately 1.5 mm thick and 2mm tall.
   / o rings for new holland tc30 injector pump #2
Welcome
Suggest posting the make and model of the pump, IMing thepumpguys on this forum, and/or contacting Spencer Diesel in Indiana
   / o rings for new holland tc30 injector pump #3
Why not contact the pump manufacturer?
Welcome
i contacted spencer diesel they said if i put the seals in i should figure overhauling my engine shortly they also said i should send the pump to them for rebuild. my grandson happens to be a graduate and has a degree in diesel technology so i am pretty sure he knows what he is doing.
since it is an engine made overseas i wouldnt have the slightest idea how to contact them. i ordered some o rings on amazon and going to see if they will work. if nothing else will get my grandson to replace the pump. a remanufactured is only around a thousand.
   / o rings for new holland tc30 injector pump #5
This is an off the wall guess. But hydraulic shops always have a huge selection of O rings. Different purpose, but maybe…
   / o rings for new holland tc30 injector pump #6
Your New Holland dealer doesn't have the correct O rings? When I had to do do some work on my TC33D, I just used the parts manual and ordered the rings from my dealer - they had most of them in stock. I probably could have found them cheaper, but it would have taken too long to figure out exactly what they all were and find a source. Turns out, I'm glad I didn't try to find them on my own: a couple of the O rings had unusual hardness ratings - something I would have missed had I just been measuring and ordering based on size.
2015 KUBOTA M9960 LOT NUMBER 214 (A53084)
2015 KUBOTA M9960...
2022 CHEVROLET 2500HD CREW CAB TRUCK (A51406)
2022 CHEVROLET...
2013 MACK GU713 (INOPERABLE) (A52472)
2013 MACK GU713...
LOT LOCATIONS (A52576)
2018 FORD F-150 (A52472)
2018 FORD F-150...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
