O ring needed
/ O ring needed #1
jwcinpk
Welfare Capital of the World...KY
2009 Mahindra 3316 HST-2008 Mahindra 7010 cab - 2004 Mahindra 6000 4X4
I need an o ring for the loader valve of my 7010 cab Mahindra.
According to KMW the proper O ring would be 3/4 ID and one hundred thousands thick.
Anyone recommend a supplier?
/ O ring needed #2
You need more information than that. You will be better if you use the metric measurements and DIN designation. This could be a flat O-ring or round O-ring. Also what material doe the O-rings need to be made out of? Do you need a Vitom O-Ring? First off I'd call Dave's Tractor and ask Rob what you need. THe OEM parts will not be that expensive.
/ O ring needed #3
If it's on a loader valve it's a 90 durometer, buna-n o-ring. The dimensions sound like a -10 o-ring. .755" I.D. by .090" thick. Take the whole fitting to and decent hydraulic hose shop and they should have plenty. There is a post here in the hyd section about a company with o-ring kits on sale, the o-ring you need is in one of the kits.
/ O ring needed #4
I use this Oring site for my needs. They will sent you a sample also if you ask. They had at one time an online Oring dimensioning selection guide, of available Orings that they carry. Plus they are extremely reasonably priced, as opposed to Apple Rubber, whom I used to use. I mostly need very small Orings for lab research equipment, but P.A. carries all sizes. Hope this helps.:)
Precision Associates, Inc. Rubber Seal Solutions
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2006 PROCO 130BBL (A65643)
2006 PROCO 130BBL...
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2017 FREIGHTLINER M2 WATER TRUCK (A65643)
2017 FREIGHTLINER...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
New 11'x19' Steel Carport with 10' open sidewalls  (A62679)
New 11'x19' Steel...
