O-ring for quick coupler, female internal
/ O-ring for quick coupler, female internal #1
al3
Central Wi
JD 4110, X500
Anyone figure out the correct size internal O ring for a Deere LV10908 coupler? Used on early to mid 2000’s 485, 3033, 4110 and a bunch other. Did a TBN search and couldn’t find any discussion. O-ring listed on Deere site (R26375) is external. Thanks
/ O-ring for quick coupler, female internal #2
Probably the best way to go would be to get an assortment from Harbor Freight, you should be able to match it to one, then get that size from McMaster Carr or similar if you go through a lot of them.
/ O-ring for quick coupler, female internal #3
Al3
That part number isn't a working number. Possible it is incomplete ??
/ O-ring for quick coupler, female internal #5
LV10908 is an incorrect JD part # but LVA10908 is correct part #. After performing some research I located an o-ring part #R21722 used inside similar breakaway couplers with different part #s . It may or may not be correct part but it would not cost that much to check it out. Another option is remove old o-ring & measure it then check for size in o-ring kit or hyd repair business.
/ O-ring for quick coupler, female internal #6
I have this posted on the GTT forum:
Here are the common sizes used, they are available from MANY sources:
For 1/4" ISO 5675 "AG" style couplers:
Size = 113
Durometer = 70A
Material = Buna N
For 1/2" ISO 5675 "AG" style couplers:
Size = 117
Durometer = 70A
Material = Buna N
Yes, my typing skills are sorely lacking and missed the “A” key when entering LVA10908.
Kennyd, thanks for the info. Did a few more searches and eventually found the thread you referenced. Someone at the end mentioned Pioneer 4050-15P-488 might be a substitute. Ever get any feedback that these will indeed work with the OE JD male side?
Rooster Weathervane (A59231)
Rooster...
2003 John Deere 110 Backhoe (A59213)
2003 John Deere...
SWICT 84" SKID STEER BUCKET (A60430)
SWICT 84" SKID...
UNUSED ZJG ZJ-380 STAND ON SKID STEER (A60430)
UNUSED ZJG ZJ-380...
40' High Cube Multi-Door Container (A53314)
40' High Cube...
20.7kW Aptos 440W w/ IQ8PLUS Enphase Microinverter Solar System (A59228)
20.7kW Aptos 440W...
