nx6010 transmission fluid spec?
   / nx6010 transmission fluid spec? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a NX6010 Cab model. Why does the owners manuel say 11.9 gallon for the transmission fluid and replacing transmission fluid and filter it says 14.6 gallons. Which is the right one?
   / nx6010 transmission fluid spec? #2
I would call the dealer and find out. If you are still unclear, measure the amount coming out. Also refill with 11.9, then check it. It is easier to add than take away.
   / nx6010 transmission fluid spec? #3
Beats me which is right. Fill until on the dip stick. Start engine. Let run for awhile. Cycle power steering, cycle three point, cycle loader. Shut engine off. Check dipstick fill to the lower to middle band on dipstick as the fluid will expand when warmed up.
   / nx6010 transmission fluid spec? #4
I believe the the 11.9 is for a gear model and the 14.6 is a hydro model.
2014 GMC Sierra Pickup Truck (A50323)
2014 GMC Sierra...
2019 FORD TARNSIT CONECT CARGO VAN (A52577)
2019 FORD TARNSIT...
2015 Kubota RTV-X1100C (A52748)
2015 Kubota...
2018 KENWORTH T680 SLEEPER TRUCK (A52576)
2018 KENWORTH T680...
2002 Western Star Trucks 4900 SA Truck (A51692)
2002 Western Star...
2014 FREIGHTLINER 108SD WITH ELLIOT H110 CRANE/MANLIFT (A52472)
2014 FREIGHTLINER...
