nx6010 transmission fluid spec?
   / nx6010 transmission fluid spec? #1
HK45
Bethlehem, Pa
Kioti nx6010 loader backhoe
I have a NX6010 Cab model. Why does the owners manuel say 11.9 gallon for the transmission fluid and replacing transmission fluid and filter it says 14.6 gallons. Which is the right one?
   / nx6010 transmission fluid spec? #2
I would call the dealer and find out. If you are still unclear, measure the amount coming out. Also refill with 11.9, then check it. It is easier to add than take away.
   / nx6010 transmission fluid spec? #3
Beats me which is right. Fill until on the dip stick. Start engine. Let run for awhile. Cycle power steering, cycle three point, cycle loader. Shut engine off. Check dipstick fill to the lower to middle band on dipstick as the fluid will expand when warmed up.
   / nx6010 transmission fluid spec? #4
I believe the the 11.9 is for a gear model and the 14.6 is a hydro model.
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
2005 Mack CV713 Granite Truck, VIN # 1M2AG11C55M020965 (A51572)
2005 Mack CV713...
Intermodel Metal Storage Crate (A51573)
Intermodel Metal...
2022 Polaris Ranger 4x4 Utility Cart (A51691)
2022 Polaris...
2015 PETERBILT 389 TRI-AXLE MID-ROOF SLEEPER (A52472)
2015 PETERBILT 389...
2018 Nissan Titan Pickup Truck, VIN # 1N6AA1E57JN515039 (A51572)
2018 Nissan Titan...
