kapper
Well, as some of you know I've been complaining about my hydro transmission seemingly 'slipping,' or having an excessive lag time. The Dealer, who has been fantastic so far, came to pick it up last week and they recalibrated the hydro. They tested it for about 2 hours and it worked great. They brought it back and I went to work on the new driveway project and it worked great!.... For about the first 3 hours...
Then, it started slipping, or hesitating again. So, yesterday Little Tractor sent out Mike, who I believe is the head mechanic. He again recalibrated the hydro and this was him test driving it. He was nice enough to level some dirt that I had drying out! Anyway, it was a good visit because between the two of us going over the issue, it caused him to identify two potential problems!
The first was that (If I have this all correct) on the newer tractors Kioti was putting on some hydro filters that the screens were actually too fine. They have swapped out a few filters (that were the next level down on screen size), to increase the hydraulic flow. He told me the technical specs/numbers on the filters, but I don't recall that part, but you get the idea.
Secondly, he saw that I have the 3rd function on the front and he looked at the valve used on it, and said it was a 'small' valve and that it was likely only allowing 8 gpm, when the system is pumping 12gpm (the part not including the power steering, as the whole system is like 17 gpm). He had this exact same issue on a DK shuttle tractor when a 3rd function was installed with a valve that was too small. The shuttle was also kind of 'slipping,' would not move very well, and was just plain tough even getting it to shift smoothly.
So, he ordered two new hydraulic filters and is going to get a bigger valve for the 3rd function. I am very pleased with that! I was really worried that this was going to be one of those 'phantom' issues that would net get resolved! I was beginning to wonder if they really believed me when I described what was happening!! Because, of course when they tested it, there was no problems!
The main symptom we identified was that each of the time it started acting up I had been doing loader work for a couple hours. So, it was HEAT that was consistent. After it got good and hot, then it started acting up, which makes perfect sense that either the filters are a bit too restrictive, and/or that valve, which was causing the fluids to run too hot, and either restricting flow, or possibly (but less likely) causing the solenoids to act up if they were getting too hot.
Hopefully, these changes will cure this thing once and for all!! I'll report back probably next week after they get the changes made. Rock on boys!!
