NX6010 HST stops moving
   / NX6010 HST stops moving
Yes I did check this the other day as I also read of that possibility, but the wheel wasn't spinning. Thanks for the response
   / NX6010 HST stops moving #12
Have a NX6010 HST and for the past two years, it will periodically cut out of forward motion ( like a tranny that would slip into neutral on a car ), while the engine rpm stays at full throttle. Won't go forward or backward. When I take my foot of the petal and let the rpm's go down to idle and wait 10 to 15 seconds, then re engage the forward petal. it will go again. Generally happens under load, like going up a hill or blowing snow, but occasionally on the level with no load. Will only happen at high rpm. This is an intermittent problem that the dealer has tried to fix but to no success. Of course it NEVER happens at the dealer when they try to make it happen. Any ideas?
Frustrated in Minnesota
I think it is a software problem but only if you have the throttle/speed/whatever-it-is-called switch on. If the switch is on, at max throttle in high gear you can jam on the go pedal and the machine will not move. Move the go pedal slower and off you go.
Also this problem can happen if your hydro oil is cold. I put a warmer T-stat into my NX6010 and it fixed all my drivability problems--from the engine not operating warm enough (as in it would go cold at idle at 35 degrees and colder), to faster warm-up of hydro oil, to a bunch more power (because the engine is now operating at the proper temperature).
If the fault isn't something stupid like I've suggested then pull the electrical connections apart and reconnect them--especially the pedal position sensor and the two pin switch that can get disconnected on the underside left hand portion of the transmission.
Thanks,
They are looking at all connections and we will see what happens.
   / NX6010 HST stops moving #14
Did you ever get a root cause on this? Just wondering if it might be the same problem I have, air in the hydro line. My tractor doesn't stop moving entirely, but it certainly feels like a "slip" and the tire is spinning on the rim (it's not).
Also, Eric, you happen to have the PN for the warmer tstat? I have similar problems, my NX takes a really long time to warm up, and if I let it idle in the cold, it'll get below the middle of the range.
Kioti decided to replace the entire hst system. They have to split the tractor in half to do it. Of course I知 without a tractor until they get the parts and then install them. Hopefully it won稚 snow much intil it痴 finished.
   / NX6010 HST stops moving #16
Wow, that's extreme.. They're replacing the tranny too, not just the HST "power side" (pumps/filter/etc)? I'd love to know why they are doing that, it seems that the problem is likely on one side or the other, either the pump is a problem or the tranny is the problem, not both, right? In my case, it's obvious the problem is on the power side because all my hydraulics have issues, not just the tranny; my FEL is jerky, 3pt, external hydro accessories. They all "slip", and the reason they slip is because (current theory) the pump is bad and it's putting air in the system. But it's easy to figure out if that's the problem (look for bubbles in the fluid and listen for cavitation).
I'd be happy if they'd do this for me, so, good for you, but man, that's a big repair, just seems there are a lot of things to try before dropping the HST and replacing the whole thing?
   / NX6010 HST stops moving #17
The Stant 48808 is a drop in replacement. You'll need to get a factory t-stat gasket or make one out of gasket material. I make them out of 3075.
JOHN DEERE 10 LUG TRAILER RIM (A52708)
JOHN DEERE 10 LUG...
Giyi Mini Pallet Forks (A57149)
Giyi Mini Pallet...
Hydraulic Tilt Bucket Mini Skid Steer Attachment (A56857)
Hydraulic Tilt...
UNVERFERTH 330 - 22-INCH EXTENTSION TUBE FOR BASE AND WING ASSEMBLY FOR RIPPER (A55315)
UNVERFERTH 330 -...
2015 Nissan Altima Sedan (A54815)
2015 Nissan Altima...
2020 4-Fuel 800 Gallon Fuel Tank, Model 4F-838, S/N 4F-838811/20, Nominal Capacity, 838 Gallon/3172 (A59076)
2020 4-Fuel 800...
