NX6010 HST stops moving
   / NX6010 HST stops moving #1
joro2548
Ramsey , MN
Kyoto NX6010 HST Cab
Have a NX6010 HST and for the past two years, it will periodically cut out of forward motion ( like a tranny that would slip into neutral on a car ), while the engine rpm stays at full throttle. Won't go forward or backward. When I take my foot of the petal and let the rpm's go down to idle and wait 10 to 15 seconds, then re engage the forward petal. it will go again. Generally happens under load, like going up a hill or blowing snow, but occasionally on the level with no load. Will only happen at high rpm. This is an intermittent problem that the dealer has tried to fix but to no success. Of course it NEVER happens at the dealer when they try to make it happen. Any ideas?
Frustrated in Minnesota
   / NX6010 HST stops moving #2
When you say "full throttle" do you mean just that or Max revs for the task at hand?
My 4105 has a 'sweet spot' at just a titch over 2000, then there's the working with the PTO running revs and the 'on the road' revs (2500). Full/maximum revs would only be used in a dire situation and not for long as it may over-tax an HST.
   / NX6010 HST stops moving #3
Joro2548, I'll mention this just to rule it out as the cause. Are you certain that you aren't inadvertently hitting both the forward and reverse hydro pedals at the same time? Most commonly happens doing loader work with heavy boots on (or very large feet :) ), but the symptoms are similar to yours.
Simultaneously catching the second pedal with the edge of your foot, even momentarily, will put the fly-by-wire HST control into "safe" mode, and you'll be dead in the water for a few seconds until it resets. If you press either pedal in the interim, before it resets, it will keep cycling in safe mode.
   / NX6010 HST stops moving #4
Can you catch a video of it happening? This would at least provide some additional info to your dealer.
I use the linked in pedal switch so that as I press the forward pedal down, the rpm's increase, like on a car pedal
definitely not hitting both pedals at the same time. Not saying it's never happened, but not consistently when having this problem. Thanks
What does the fly by wire control. Maybe the electronics of the fly by wire are failing intermittently. As I mentioned in the initial post, when the drive kicks out, the rpm's do not drop
   / NX6010 HST stops moving #8
Joro2548, I don't know the particulars of the HST fly-by-wire circuitry, but the idea that your issue might be electrical seems quite logical. See post #1123 in the following TBN thread from a couple of years back: https://www.tractorbynet.com/forums/kioti-buying-pricing/315694-my-nx6010-113.html
I haven't checked, but I suspect the NX service manual has an explanation of how the HST pedals signal the transmission, along with a circuit diagram. Do you have access to one? IMO, this is certainly worth raising with your dealer's tech. Your sudden loss of forward and reverse operation seems identical to what happens in "safe mode" when inadvertently pressing both pedals. Just speculating here, of course, but it might even be as simple as a loose or damaged wire, or a faulty pedal-pressure sending unit.
Here's a thought that might help with the diagnosis. While driving forward and continuing to keep pressure on the forward pedal, use a short length of wood, long screwdriver, etc. to lightly press the reverse pedal momentarily. Watch the dash to see if the CAL light comes on, and if the condition replicates.
Keep us posted on this. These NX tractors have been sold for about five years now, and have been very reliable.
Thanks Threepoint, I will definitely raise this point with the dealer on Monday. Thanks for everyone's input
   / NX6010 HST stops moving #10
Have you checked your tire pressure some people have had the same issue and it turned out the tire was slipping on one of the rims. Usually happens with rim-guard filled tires and low tire pressure.
2009 Haybuster GP-50 Grain Processer (A55315)
2009 Haybuster...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2017 Anderson Prochop-150 (A53317)
2017 Anderson...
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
Pickup Truck Bed (A55973)
Pickup Truck Bed...
2015 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2015 Ford F-150...
