NX5510 will crank but not start..
   / NX5510 will crank but not start.. #1
Cthomp55
Oneida, Tn
Kioti NX5510
Hey folks...
Need some guidance.. 2017 NX5510 approximately 200 hours will crank, but not start. Would not start. Then replaced fuel filter with new fuel filter. Lines cleared and will pump fuel to the injector pump, but that's it... Any ideas.
Thanks,
Thanks for the reply... Could it have gotten air in the lines prior to removing the filter?? The issue started then the filter was changed...
Thanks
   / NX5510 will crank but not start.. #4
May not be getting fuel to the injectors.
You are still in warrantee.... call the service department and get advice from them. They may have to send someone out.
   / NX5510 will crank but not start.. #5
So u HAVE FUEL TO the inj. pump but nothing out..
It could be air & u loosen the lines AT THE INJECTORS & crank the engine until the air is expelled & retighten the lines..
OR.. it could be the shut-off solenoid .. or a fuse going to the shut off solenoid..
Is this a tier 3 or 4.?? Mechanical injection or common rail.??
   / NX5510 will crank but not start.. #6
These are the new tier 4 common rail.
   / NX5510 will crank but not start.. #7
Might be late to the party, but...
I suspect you might have a fuel blockage. Check that your line from the fuel tank isn't pinched: I once managed to get a stick jammed up underneath on the tank side that wedged the line closed against the frame. Also might want to disconnect that line to the filter and blow back through it (loosen up fuel cap): this is how I found out my line was pinched- hauled my portable air tank out and blew back and got nothing but resistance!
If you get it to run momentarily and it then shuts back off it could be that there's debris inside the fuel tank that is being sucked up against the outlet (and it'll drift back away when the engine shuts back off- loss of vacuum to pull the debris against the outlet). I also had this situation, but it was due to an ice pellet! (looking back, that happened around 100 hrs, I think it was the result of a crappy fuel cap (allowing water in; I was getting water-in-fuel fairly regularly, and ONLY on this tractor [not on any of my other diesels- all using fuel from my on-site tank])- dealer got me a new one, one that was slightly different [suspect design change]- first cap's key had cuts on one side only and it felt really cheap; second cap's key has cuts on both sides and feels a lot better).
Tractor is actually at the dealer now and they suspect it will need a new computer... Go figure...
   / NX5510 will crank but not start.. #9
Any resolution to this? Always looking for helpful answers! :)
Tractor was returned to dealer 4 weeks ago tomorrow. Still not fix. Replaced the computer and tractor will start now, but has very little compression in 1 cylinder...
Thanks for checking
2020 INTERNATIONAL LT625 (A52472)
2020 INTERNATIONAL...
2001 INTERNATIONAL 4700 4X2 SERVICE TRUCK (A57192)
2001 INTERNATIONAL...
2010 Blue Bird BB Conventional School Bus (A55852)
2010 Blue Bird BB...
2012 International 4300 Reefer Truck (A57024)
2012 International...
Chery 7' 35 Drawer Workbench (A50120)
Chery 7' 35 Drawer...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A55852)
2016 Peterbilt 320...
