NX5010 with ROPS
/ NX5010 with ROPS #1
trctorfan17
northeast
none
Hi,
I am considering buying NX5010 HST.
I can't find anywhere the exact height with the ROPS folded.
Does anyone out there has or knows the height of Kioti NX5010 with the ROPS folded?
I want to know if it can fit through my garage door.
Thank you very much.
/ NX5010 with ROPS
Thanks Jeff9366...True, I am considering the NX5010H with loader KL6010 and backhoe KB2485.
I thought I can lower the backhoe as I drive slowly, then I can adjust. My garage is 25' deep and height is limited only at the door.
/ NX5010 with ROPS #3
I'd call a dealer near you and ask them to measure to the fold point of the ROPS. I doubt you'd find it out anywhere else, unless you ask someone here who owns one to measure it for you. You might also want to see what the overall length would be with the hoe folded partway down. It might be more than 25' overall length. You could do what I do, since I have the same hoe; I remove whatever I have on the FEL and just go into the bay with the FEL QA feet as the most forward item, instead of the bucket or some other implement taking up additional space.
/ NX5010 with ROPS #4
I mesured mine right at 7 ft. folded. I have 8 ft. high doors, so no problem for me. If you have 7 ft. high doors, it will be very close.
/ NX5010 with ROPS
Thank you very much hill wood.
Do you have R1 or R4 industrial tires?
/ NX5010 with ROPS
R4 tires.
Great, if R4 tires give you height of 7 feet with ROPS folded, then R3 turf tires will give height of 6'9" and that can fit through my 6'10" door.
Thank you very much hillwood
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
Ford 340B Loader Attachment
Ford 340B Loader...
2003 TEREX  60 TON CRANE (INOPERABLE) (A67714)
2003 TEREX 60 TON...
2025 Wolverine ADB-13-1218R Hydraulic Auger Set Attachment (A66734)
2025 Wolverine...
STERTIL SKY LIFT (A67714)
STERTIL SKY LIFT...
2011 FORD F-250 SUPER DUTY (A67714)
2011 FORD F-250...
