NX5010 - H/M/L Range Selection
   / NX5010 - H/M/L Range Selection #1
nrpdsgt
Florida
Kioti NX5010
Just took delivery of my new NX5010 a week ago. I have to say that the brake/neutral range to start the tractor is a pain. I can live with it I guess, but I am having difficulty getting the range into gear after starting. Is there some easy way to do this. I've found that putting a little pressure on the forward petal and pulling the lever back a little sometimes will do the trick, but sometimes it takes a while to get it to go into M, which is what I mainly use. Am I doing something wrong?
Thanks,
TJ
   / NX5010 - H/M/L Range Selection #2
With both my dkse hst's I have a bit of trouble engaging into L M or H. I know, when starting, getting into neutral is easier with the brakes disengaged and a pedal touch. This got easier as the tractor aged, and I got a feel for the right pressure to apply. I don't really notice it anymore, where at first this felt like it was going to be a problem.
   / NX5010 - H/M/L Range Selection #3
My CK3510 is the same way. Have to give it a tiny bit of a pedal touch and it will shift right in. Dealer said as they get a bit older and worn in it will improve.
   / NX5010 - H/M/L Range Selection #4
Also, congrats on the new tractor, and welcome to the forum!
Thanks for the info and the welcome aboard. This is a great site for information.
   / NX5010 - H/M/L Range Selection #6
My 5010 is the same. If it doesn't want to shift range easily, without putting pressure on the shift lever, I usually press a little forward pedal and then press a little backward pedal and it will then shift easily.
   / NX5010 - H/M/L Range Selection #7
I find having linked pedal engaged and then tapping the forward or reverse to rev up the engine a little helps get everything aligned for shifting.
   / NX5010 - H/M/L Range Selection #8
I know the frustration.
First, it has been said that, and so far I believe that I'm seeing it to be the case, shifting improves a bit over time. I've got about 230 hours on mine and I suspect that it is a bit better.
I too, as cutthroat suggests above, find that running the RPMs up a bit helps. I just run the lever up a bit: I don't like linked-pedal in regular use because it seems to want to rev the engine more than I like, in which case I don't have it on for doing cutthroat's trick (which, again, would seem to be a good one [two birds with one stone, as it also addresses the next trick]).
Playing with [just] the travel pedals can help, and sometime I do that as well. If they don't respond I tend to resort to setting the throttle (as noted above), though more and more I'm finding I have better success at manipulating the RPMs.
Early on I found that cranking the steering wheel a bit also helped.
2019 Dodge Journey Crossroad SUV (A53424)
2019 Dodge Journey...
2017 Takeuchi TL8R2 Compact Track Loader Skid Steer (A55851)
2017 Takeuchi...
2018 CATERPILLAR 259D SKID STEER (A52707)
2018 CATERPILLAR...
UNUSED FUTURE TP25 25" HYD TREE PULLER (A57193)
UNUSED FUTURE TP25...
2015 Chevrolet Silverado Pickup Truck (A57024)
2015 Chevrolet...
UNUSED IRMC HIGH END ELECTRIC MASSAGE CHAIR (A57193)
UNUSED IRMC HIGH...
