NX4510HST Smoking and Rapping
   / NX4510HST Smoking and Rapping
If they get all the issues cleared up and it seems to be running good the first thing I would do when it got home would be to throw a "test pipe" in the exhaust and see how it ran.
Do you know of anyone that has done this with success? There is a smog related heat sensor on the intake side of the DPF.
   / NX4510HST Smoking and Rapping #12
Just my two cents here. It's possible that your injectors are good.
When a DPF have many failed regens, the extra fuel give by the injectors ends up going on the oil, therefore increasing the level on the dipstick. This happens a lot in my small country with diesel vehicles with DPF because the engine just doesn't run enough. Usually short 3 to 6 mile trips to and from work for most people.
Now, the failed seals on the turbo would cause oil to go on the intake. We all know what happens when an engine eats oil, all that smoke and such is not good for the DPF and will plug the DPF quite fast. Then you get a bunch of failed regens. Everytime a regen happens, the ECU will send info to deliver more fuel to increase the temperature at the DPF. Again, with failed regens, the unburnt fuel ends up in the crankcase.
Most on vehicles, but some engines will have a mark on the dipstick above the regular oil level, that indicates that the oil should be changed because it's too much diesel diluted in it and increased the level.
   / NX4510HST Smoking and Rapping #13
Not on the Kioti per say but many people that s=do so will not advertise doing so,
you could put a tap in a test pipe for the temp sensor and any pressure or differential pressure sensors.
A orifice in a pipe could provide a small differential pressure if needed.
What you say makes a lot of sense because I checked the oil level on a slight incline on Sunday and it was just a little over full. I figured that was because the tractor was aimed uphill and the stick was on the downward side. That means that this machine dumped a lot of fuel into the oil in a very short time.
Yup, that would fix that. Also emptying out the DPF would also make it a straight chamber. I have seen catalytic converters that were cut open and the inards removed then welded back up.
   / NX4510HST Smoking and Rapping #16
Amazing how the inards just disapeared :dance1::thumbsup:
   / NX4510HST Smoking and Rapping #17
Not sure if it's that easy on Kioti, like it is on a Branson.
Kioti uses Common rail engines and the DPF is tied together with the engine, electronically speaking.
Once the DPF is gutted, I'm sure the differential pressure sensors will throw a rave party. :laughing:
My tractor only had one failed regen at the very end when it started smoking bad and I had to shut it down. The other ones all shut the light off.
   / NX4510HST Smoking and Rapping #20
I am afraid with the Kioti it will go into reduced power mode if the computer does not see the proper parameters. Another member here, MinnesotaEric believes he has found a way to fool the computer but I don't think he has installed it yet.
Here is his thread.
https://www.tractorbynet.com/forums/kioti-owning-operating/420871-generic-dpf-filter-delete.html
Sorry for your troubles but this is the very reason I choose Branson over the rest when I was in the market last year.
UNUSED SDLANCH SDLE20 EXCAVATOR (A58375)
UNUSED SDLANCH...
Giyi 72" 4-N-1 Bucket (A57149)
Giyi 72" 4-N-1...
UNUSED INDUSTRIAS AMERICA SK72 - 72" BRUSH CUTTER (A58375)
UNUSED INDUSTRIAS...
UNUSED FUTURE 513 MASSAGE CHAIR (A58376)
UNUSED FUTURE 513...
4ft Pallet Forks (A57454)
4ft Pallet Forks...
Hydraulic Excavator Thumb (A57454)
Hydraulic...
