NX series Anti Stall function..... killed it 4 times
   / NX series Anti Stall function..... killed it 4 times #11
Anyone else ever kill their engine even with the Anti-stall function on? [snip]
I've experimented a bit with this on my NX4510HST to see what the limits might be with ground engagement. I was able to kill the engine pulling a 7' Woods BSM84 box blade full of wet crusher run up a 15 to 20 percent grade when I did not shift out of mid-range. No problems with the same pull in low-range, but in mid-range the engine lugged way down without stalling for several seconds, and when I didn't relent, it finally died. The anti-stall feature seems to works very well for my use. I've not been able to kill the engine doing loader work, even with a Tisco tooth bar to give me more bite. But I can't say I've put it to the same test that Joe has.
Bi-Parting Driveway Gate (A55853)
Bi-Parting...
2021 Allmand Bros Maxi-Lite II 20kW S/A Towable Light Tower (A55973)
2021 Allmand Bros...
UNUSED WOLVERINE SBG-13 72W 83.2" SLIDING (A57193)
UNUSED WOLVERINE...
2014 Freightliner M2 106 5.1Yds Asphalt Pot Hole Patcher Truck (A56858)
2014 Freightliner...
2021 Caterpillar 308CR (A53317)
2021 Caterpillar...
2017 John Deere 6120E (A53317)
2017 John Deere...
