NX Loader able to curl and lift at the same time?
   / NX Loader able to curl and lift at the same time? #1
waendo
Vancouver, WA
Long 2485 and shopping
Test drove an NX4510 last night. There was a loader diagram, pic attached. The loader would not lift/drop and curl at the same time. From reading other posts and looking at the diagram, I believe that should be possible. Is it possible that the loader was installed incorrectly?
Thanks.
   / NX Loader able to curl and lift at the same time? #2
At max rpm it will but not at full input on both controls. It takes some finesse to get both actions.
This is the diagram.
Do other brands do this more easily?
   / NX Loader able to curl and lift at the same time? #5
Mine was tough at first to get it to do both, but as the cables relaxed the more I used the loader it has gotten much smoother and easier to do.
Not sure how many hours you have on the machine, I only have a little over 700.
   / NX Loader able to curl and lift at the same time? #6
Haven't really tried to do so purposely on mine, but I can try it when I get back to the house. Out of town for the next week or so. Sorry!
It's a 2018 built NX4510 with 26hours.
   / NX Loader able to curl and lift at the same time? #8
Construction type machines do but they have (in general) a lot more hydraulic flow. Ag tractors are intended to do a myriad of different chores with acceptable performance at a moderate price point.
I really like the value of the NX, but wondering if I will be frustrated by the slow FEL, I have a lot of dirt work to get completed.
   / NX Loader able to curl and lift at the same time? #10
The loader valve is not piloted, so one function at a time unless really feathered.
2007 Ford F-150 Crew Cab Pickup Truck (A53422)
2007 Ford F-150...
UNUSED WOLVERINE MSG-11-44W 44" HYD STUMP GRAPPLE (A57193)
UNUSED WOLVERINE...
Freightliner Tender Truck - Adams Tender (A55301)
Freightliner...
2016 KBH Fertilizer Tender Trailer - Isuzu Diesel, Hydraulic System, Rear Discharge (A57024)
2016 KBH...
UNUSED WOLVERINE MAD-12-12D HYD AUGER DRIVE & BIT (A57193)
UNUSED WOLVERINE...
40' CONTAINER (A51244)
