'nuther question (suzuki tcase)
   / 'nuther question (suzuki tcase) #1
towmotor
Bronze Member
I've been hearing alot about the Suzuki Samurai transfer case. It being a divorced unit has me interested in trying one to get a little more grunt for my anticipated tractor build.
Does anyone know what the torque capacity of these units is?
   / 'nuther question (suzuki tcase) #2
I dont know the capacity, however there are many web sights catering to Samurai's ( lots of aftermarket gears too). I'm sure one of those will know.
I have a transfer case left over from my build, if your interested?
I might be interested indeed. I guess it depends on how much it's worth to both of us...
My only alternative is to make an input shaft for the NP208 I already have. Not very attractive.
I'll let you know.
   / 'nuther question (suzuki tcase) #4
Geo Tracker and Suzuki Sidekick transfer cases are also divorced units.
   / 'nuther question (suzuki tcase) #5
Samurai
1,298 cc 1.3 liters 4 in-line front longitudinal engine with 74 mm bore, 75.5 mm stroke, 9.5 compression ratio, overhead cam and two valves per cylinder
- Unleaded fuel
- Fuel economy EPA highway (l/100km): 8.1
- Single-point injection fuel system
- 40 liter fuel tank
- Power: 49 kW , 66 HP @ 6,000 rpm; 76 ft lb @ 3,500 rpm
So approx 76 foot lbs. If your ganging transfer cases the weeker one should be in front. Samurai transfer case is all gear with aluminum housing. I still have one kicking around waiting for a project.
   / 'nuther question (suzuki tcase) #6
Samurai
- Unleaded fuel
I'm not quite sure that is what the gear case can take, I sure hope it will take a lot more than 76ft # of torque!
I'm willing to bet it will ( think about it, a guy with a breaker bar can easily apply 76#).
   / 'nuther question (suzuki tcase) #7
Those torque and power numbers for the Sammy engine are at the
crankshaft. Torque is multiplied many times before it gets to the xfer
case or the tires.
I have an 88 project Samurai and the Xfer is tiny and very easy to
rebuild.
   / 'nuther question (suzuki tcase) #8
Ya forgot about that part, so I think 1st is about 3.65 or 4:1 so you looking at 275-300 lbs input and with 2.23 low, approx 600ft lbs output torque. I used an SJ410 T-case with 2.5 low range, though I don't think they sold that model in the USA.
   / 'nuther question (suzuki tcase) #9
Tracker/Sidekick/Vitara are NOT divorced transfer cases. You can get gear sets for both types cases. Sami is neat because changing the gear set in a Sami case changes both the high and low range.
2017 Chevrolet Silverado 3500HD Ambulance (A52377)
2017 Chevrolet...
2023 New Holland Workmaster 25S Compact Tractor - Only 65 Hours (A53473)
2023 New Holland...
2023 NEW HOLLAND HYDRAULIC THUMB FOR B95D TLB WITH STANDARD STICK (A53473)
2023 NEW HOLLAND...
2025 AGT YC-32G (A50123)
2025 AGT YC-32G...
1994 MACK RD688S BOBTAIL VACUUM TRUCK (A53843)
1994 MACK RD688S...
