nukelbuster
/ nukelbuster #1
nukelbuster
topeka,ks
ihc cub cadet
147 cub cadet with 321a kohler engine. the engine will idle fine but will not rev up without sputtering and stalling. with the air filter off it does blow a little gas back out of the carburetor when trying to rev up.
/ nukelbuster #2
Possibly could be as simple as needing the carb adjusted, to needing to clean the carb, or adjust the valve clearances.
/ nukelbuster #4
depending on the year , it still might have points and condenser ... or the coil is weak... does it spit black smoke from the exhaust when it stumbles ?
/ nukelbuster
thanks everyone for your help. we finally figured out that the kohler needs a coil with a built in resistor. put on the right coil and it runs great. thanks. nukelbuster
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
7002SFL (A61572)
7002SFL (A61572)
2023 ASV RT-25 Posi-Track Compact Track Loader Skid Steer (A64553)
2023 ASV RT-25...
Cattle Feeder (A65640)
(1) HD 24ft Free Standing Corral Panel (A65579)
(1) HD 24ft Free...
Calf Creep Feed Hut (A66408)
Calf Creep Feed...
