Now ready for the concrete in the pole barn
   / Now ready for the concrete in the pole barn
Spend the wooden nickel and put rebar in. A typical slab would be #4 rebar at 18”-24” OC with 12” overlap on the joints. You could knock that out in an hour or so. Dobies are a good idea too.
It’s not like you get a second shot at it.....
I will see what the contractor recommends. If I go the rebar route then the truck can't back in. It will take 100 20' sticks of rebar !!
   / Now ready for the concrete in the pole barn #13
The first thing that I need to see in a concrete contractor is if they are using rebar set on chairs. If I don't see that, they don't pass the test. When they tell me that they lift it as the go, I know that they are a liar, or incompetent. Either way, it's not possible to work concrete and lift rebar, and walk all over it at the same time. For that very reason, wire should never be used on a big pad. If you have to walk on it, wire is pure junk. Fiber doesn't hurt anything, and it does add some strength, but it will never replace rebar.
Prepare to play the game! This was my experience, I received my quote agreed to it and scheduled a date. Pour day comes all goes well and is looking great, near the end the job foreman tells me that they used more concrete than expected, that will be another $1200 for time and materials. Am I responsible because the estimator screwed up? I told him I would pay only for the additional material, I thought that was fair, I was there the entire time so I know how many trucks showed up. I’ve heard similar stories from others in my area using various contractors. Just a word of caution, best of luck!
Thats a bummer ! I have poured alot of concrete over the years and yes I have come up short a couple of times. I will ask the contractor to be sure he gets the right amount of yards !!
I am going to do the rebar myself if I go that route. Your right....pulling up mesh or rebar just doesn't work!
Not sure on some of the information. $3600 for the whole job, concrete, mesh, labor, tax ?
I am calculating about 24 yards (guessing on footing lengths) so at least 25 yards ordered.
So how much per yard from your plant and what ever is left over is labor ? If so thats a bargain. If the $3600 is labor only then its still a deal around here.
Thoughts that. You might not care one way or the other about are
1. Mesh comes in different sizes. Smaller is hard to see even when troweling.
2. Rebar and mesh do two different jobs. One is not a substitute for the other. Mesh is the substitute for the wire grid, not rebar. I personally would much prefer to have the rebar. Even 3/8 or number 3 rebar would be preferred over the mesh if I could only have one of the choices. (For those that one to argue the point look up the manufactures recommendations for use of their products).
3. Saw cuts are needed soon, as in same day or first thing early next morning.
4. The more water added the weaker the final product, and more cracking is likely. Yes I realize more water makes it easier to work. Just keep the point in mind.
5. Depth of saw cuts need to be at least 1/4 of the slabs thickness.
6. Inside corners in the concrete pour will be more likly to crack. If you have any, such as boxes around plumbing, or post.
7. Some people like to put lag bolts or some type of anchor in the posts of the building for the concrete floor to pour around.
Total price for the concrete and finishing plus expansion joints. I will do the rebar work myself. There are no footers except at the 2 door openings.
I have concrete columns so the floor goes right up against them.
I have 1 post that is in the middle for a loft support. I have already poured a 12" sono tube so that there is no sharp corners for the floor to crack.
   / Now ready for the concrete in the pole barn #17
If I put rebar in they won't be able to back in. The 14' door is high enough for them to back in. If I go with just a fiber mix then no problem for the truck to back in.
If they can't back in then it's up to you or your finish guy to get it to the back of the building. Make sure everyone understands that before the truck shows up.
   / Now ready for the concrete in the pole barn #18
I agree. I've torn out several pads with wire mesh. It's always at the bottom of the concrete. Turn a chunk over and you can see it.
   / Now ready for the concrete in the pole barn #19
Trucks drive right over the rebar- dobies in the back till he is clear of the door. Most trucks can tailgate 15-20’ so that’s of no concern.
The front form is the same regardless of reinforcement
Since I am putting various runs of pvc conduit under the slab, what size would you recommend ? 2" 1 1/2 "
1" ? Also would you run THHN wire thru the conduit ? Don't think you can run romex thru conduit.
2023 Kubota SVL75-2 Skidloader (RIDE AND DRIVE) (A50775)
2023 Kubota...
2007 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2007 DRAGON 150...
2010 John Deere TX Gator 4x4 Utility Cart (A55973)
2010 John Deere TX...
2005 Ford F-750 Truck (A53422)
2005 Ford F-750...
Fiat 250 Montagna Tractor (RIDE AND DRIVE) (A50775)
Fiat 250 Montagna...
40' CONTAINER (A51244)
