Novice question about hydro motors
   / Novice question about hydro motors #1
Lawnjocky
Bronze Member
Central Illinois
JD 3520
I don't know much about hydraulics so I need a little help choosing a motor. I think the motor I need is a Char-Lynn H series 101-1753. but I can buy the 101-1001 for $25 less. The only difference I can see and understand is the lower cost motor has a higher flow 2.8 vs 2.2. Should I spend the extra $25 or will the bigger motor work. All I'm doing is rotating a chute on a snow blower.
   / Novice question about hydro motors #2
The chute rotator motor on my Kubota front mount blower is quite small and has restrictors in both lines and still spins the chute about twice as fast as I need it to:eek:. No matter which motor you choose, power and speed will not be a problem.
   / Novice question about hydro motors #3
Bigger motor will turn slower....but with more torque...
   / Novice question about hydro motors #4
Why not put flow dividers to the hyd motor. You could set up a hyd circuit to turn the chute at a certain speed. Say your tractor has a 10 GPM pump, and you had a 2/8 splitter, the one circuit gets 2 GPM, and the other 8 GPM goes back to tank.
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-5911&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-5302-25&catname=hydraulic
https://www.surpluscenter.com/item.asp?UID=2324022016054743&item=9-4169-8&catname=hydraulic
I have a valve similar to the bottom valve, in my PTO circuit, and I can dial in the rpm of the hyd motor, and the excess goes back to tank..
2018 VOLVO VNL DAY CAB (A52576)
2018 VOLVO VNL DAY...
UPDATED INTERNET BUYER'S PREMIUM TERMS (A50775)
UPDATED INTERNET...
2013 Vermeer V800 T/A Towable Vacuum Trailer (A50324)
2013 Vermeer V800...
2012 DRAGON PRODUCTS 130BBL VACUUM TRAILER (A53843)
2012 DRAGON...
2021 Club Car Carryall 500 Utility Cart (A51691)
2021 Club Car...
MISC PALLET OF SPM PUMP PARTS AND JOSES (A53843)
MISC PALLET OF SPM...
