Nova Tractor Flail Mower Review -- First Impressions
   / Nova Tractor Flail Mower Review -- First Impressions #1
Matt VA
Virginia
2021 Branson 4820CH
So, I just put 6-7 hours into the medium duty Nova Tractor flail mower this weekend. This was the MD175 model (Formerly EFGC175 I think). It has 28 1.75 lb hammers and a 68" cut width. I think my 48 horse tractor (42 at the PTO) would have pulled the next largest one up but I preferred to lose a small amount of cut width (8 inches) to push less mass and therefore have some power in reserve in the rough stuff. This is not the HD model (MFZ) which comes with fewer 3 lb hammers with teeth. I decided that more, lighter weight hammers would do a cleaner cut in grass and still handle saplings between 1 and 2 inches. I mean, 3 lb hammers is like going to war or something and I just wanted to strike a balance with cut quality.
This mower does not have a hydro shift, which would have been nice. But only the HD model had it. If I wanted it with the lighter hammers I needed to pony up for the ditch mower and that was considerably more coin. The mower mounts offset with an overhang over the right rear wheel. There are two mounting positions for the three point bracket. I chose the more conservative offset since I expect to drive this in tighter spaces, but it gives you some wiggle room when getting up against fences.
Assembly was relatively straight forward. Just be patient. The manual is not a master piece but all the critical information is there. I added a hydraulic top link for minor adjustments to attack angle but set it once and never messed with it again. The mower runs on the back roller with skids on the size that will engage if the terrain changes suddenly.
I ended up mowing three horse enclosures. Probably 10-12 acres altogether. These had not been mowed in probably 20 months. Still just grass but heavily layered with dead growth and very thick/clumpy. I set the mower to the highest setting which is around 3 inches and went to work. Cut speed was very good and no bogging. The cut was very clean and the droppings went down right where the grass was cut. No clumping like what you would have seen with a bush hog and no throwing debris. Pulverized a few fallen limbs along the way. Ran over a few protruding rocks and it generally just bounced over. No apparent damage to the hammers. Given the height of the grass it did leave a blanket of blades across the turf (basically the dead stuff) but I suspect next mowing at a reasonable interval will leave everything looking much more clean. There were some patches of newer grass that was less overgrown and the finish on that was extremely good. Very pleased with the results, particularly at this price point. Very good value but time will tell the true value.
This was grass. I will give an update on some brush work I intend to tackle, but I expect it will do even better there.
BTW Nova Tractor was very responsive to my questions and inquiries while doing the research on what mower to buy and they picked up the phone every time. Jack, the owner, is also responsive by email. So that was a plus for me as some other import models appear to lack responsive customer service based on other reviews. I will be honest and say this was not necessarily my first choice among imported models, but they were not in stock, and it appears I have managed to find good value here. So I am happy with that.
CONS: I wish this has a hinged door on the back for easier access to the hammers when maintenance and inspection are necessary. Also, no easy way to drain the gearbox as far as I can tell. Will have to pump it out when the time comes.
Bottom line: Great first impressions. Performed better than expected and as intended relative to a bush hog. Also, love how compact it is. Since it does not hang way off the back it should be more manageable in the tight spaces I intend to go.
Cheers. Happy to answer questions. Ill post a longer term review and the end of the summer.
Matt
   / Nova Tractor Flail Mower Review -- First Impressions #2
Thanks Matt, can't wait to see how this does in brush. Though what I would be buying would be quite a bit smaller.
   / Nova Tractor Flail Mower Review -- First Impressions #4
Awesome picture! Thanks for sharing it and of your experience [so far] with your new flail. I was a bit worried I might read something bad (note below that I had already purchased one, so no turning back!).
I'm expecting the delivery of a MXZ220 next Monday. 7-footer. It's going to tax my tractor (NX5510), but I was willing to take that risk. Side-shift, for me, was/is a must: ditches and fences). This thing has 2 lb(?) hammers. I have a lot of wood debris: my 6' rotary slices and shoots chunks all over the place, which is messy- a flail will clean things up a lot nicer (this flail is rated for 2" dia, but I don't want to do a lot of that no matter what cutter is operating as it makes a LOT of racket; but, I can't tell my trees to just shed 1" branches :D).
So far, Nova has been very responsive. I'd worked with one individual for years going back and forth on what would work best. For the longest time I was aiming for a smaller unit for my Kubota, but decided that a larger unit, coupled to a larger tractor, was needed more. Anyway, over the course of at least a couple of years I was in contact. I FINALLY, pulled the trigger. Was advised of the status of my order all the way through (a delay, but the delay has little impact on me- I need a while before I can get out on my land [just shy of 34" or precip so far this year]).
   / Nova Tractor Flail Mower Review -- First Impressions #5
Year later how are the nova flails doing
   / Nova Tractor Flail Mower Review -- First Impressions #6
Just ran mine for the first time this year (2nd year of ownership). I'd had it hooked up over the winter (was greased up at the end of the season): nice ballast as it's pretty compact (and is 1,200 lbs). Only some lube on top slider tube (hydraulic shift) and I was off hitting some grass around the homestead site that was starting to get away- maybe 2 acres, so just a quick jobs. As I have LOTS of trees and ditches I probably have more to navigate than most, so mowing is a little slower for me, but not the fault of the tractor or the mower. Hoping to do some more mowing tomorrow: have tractor in my shop replacing my front video cable (cable got snagged and broke while doing some work for a neighbor early last summer, grr!). At this point, and given that price have gone up almost 20% over what I paid for mine in 2020, I'm happy with my purchase.
It's nice to have experience with a piece of machinery as one feels more comfortable with it. Can then settle in on getting the job(s) done, doing them more quickly.
   / Nova Tractor Flail Mower Review -- First Impressions #7
Thanks for update..considering there ditch mower. So was curious about actual use
   / Nova Tractor Flail Mower Review -- First Impressions #8
I had a Nova wood chipper and it's still perfect after two years.
2022 Power Screen Phoenix 3300 Tri-Axle Trommel Screener (A55973)
2022 Power Screen...
2018 HINO CONVENTIONAL TYPE TRUCK (A58214)
2018 HINO...
2000 Volvo VNL Sleeper Cab Truck, VIN # 4V4N21JF6YN250211 (A57453)
2000 Volvo VNL...
2015 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A58214)
2015 TROXEL 150...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
