Noticeable difference 2000psi vs 2250psi
/ Noticeable difference 2000psi vs 2250psi #1
bdoyle
Nevada
78 Ford 1600 & 81 Ford 1700, 1980 Bobcat 720
I am looking at pto gear pumps and the backhoe I have requires 7 GPM @ 2320 psi. Most pumps I find are rated at 2000 psi but I have seen one Chief pump @ 2250. Would I notice the difference or is it a matter of tweaking the operating RPM a bit. I don't believe the have a internal pressure relief valve or do they?
thanks!
Brian
/ Noticeable difference 2000psi vs 2250psi #2
If you have a 3 in cyl bore and 1.5 in shaft, and 2000 psi, the force would be about 14,137 lbs.
------------------------------------------------------2320 psi, -----------------------------16399 lbs
If your BH has a relief, set it same as tractor relief.
Rpm's only control the volume in GPM's.
The hyd component develops the pressure.
/ Noticeable difference 2000psi vs 2250psi #3
If it's a PD pump the RPM will dictate the flow rate. The top pressure will be regulated by the PSV.
The top pressure can be reached at any flow rate with lower rates taking more time to fill the hydraulic system.
When using my no. 7 backhoe I usually throttle way back so everything is moving slower. Makes it easier for ham handed old folk to react.
So when they say that the pump will deliver 7 GPM @ 2000 PSI it is more of a comparative tool than a limitation. I have to add a pressure relief valve when I plumb in pump and tank. Just want to make sure I do this once, correctly. I think I may just use tractor hydraulics just to test every thing out before laying out the cash on pumps ect.
Thanks,
Brian
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A59904)
2017 FREIGHTLINER...
2016 John Deere 6155R (A64119)
2016 John Deere...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2020 KOMATSU D65EX-18 CRAWLER DOZER (A65053)
2020 KOMATSU...
(INOP) 2002 CHEVROLET 3500 BUS (A59823)
(INOP) 2002...
ATS Mini Excavator (A66285)
ATS Mini Excavator...
