Cycledude
- Joined
- Nov 26, 2020
- Messages
- 1,580
- Location
- Rib Lake Wisconsin
- Tractor
- LS XR4155, Ford 6610, Ford 8n
108 horsepower wow that is a big jump from your current 20 horsepower. 5-10 GPH sounds high but you definitely can’t believe everything you read. My 55 horsepower LS with a little over 300 hours on it seems to usually use about 1.5 GPH , I have kept records of every fill, sometimes it’s only 1 GPH but it’s usually closer to 1.5 GPH.I've recent acquired a good amount of acres, but they're all steep. I have a small tractor, but it's not even close to cutting it on the hills while working (20hp). I need something bigger like an M7060 or L6060 but found a cheap Kubota M108s low profile 8 speed with 1300hrs. Of course, the horse power is way more than I need. Im going to be using a tiller, BH100 backhoe, FEL, and other equipment.
I won't be using all the HP, so I won't been to be hard into pedal. So here's the question. Does it make sense, fuel wise, to get the tractor seeing as I won't be deep into the power band to run and do what I'm looking to do? Particularly with it being 8spd.
I've looked up M7060 and they can easily get to 5+ gph full bore. An M9000 is 5 to 10gph depending on who you ask at full throttle. If this tractor is 10gph at idle it might not be worth it...but I don't know.
(edited for clarity)
So are you planning to get rid of your old tractor and attachments and buy different attachments suitable for a 108 horsepower tractor ?
