Not sure what to call it
   / Not sure what to call it #1
fcoats
Grenada, MS
Kubota 6800
can someone help me out?
I want to mount hydraulic quick coupler outlets at the front of my FEL. I plan to use a plate attached to the crossmember with holes for the lines to go through. What kind of attachments or adapters do I need to mount the hoses to the plate and then have the quick couplers attached to them?
Thanks,
Trying to add a photo
   / Not sure what to call it #4
Bulkhead fittings, as noted. Make sure you also get the nuts, or that they are included. Also make sure you allow enough space around them to get your hand on the fittings, especially with a glove on. Also, it helps to make that bracket pretty sturdy. "Things happen" and my grapple ended up hanging by the hoses on my first use...glad my bracket was 3/8" alum angle...
I just did this on my new tractor (3/8" steel):
I found these guys to be quite good too. Decent price and very fast shipping and service.
http://www.hydraulicstore.com/
Thanks for your responses.
Now if I can only find a 1/2" NPT Male to female
   / Not sure what to call it #6
There are also QD that have a two machined groove on the body of the QD that are spaced the width of about 1/8 to 3/16 inch. You put a snap ring on each side and the QD is held in place. JD uses these a lot on the 3x20 and 4x20 tractors.
   / Not sure what to call it #7
John Deere has QC with a built in bulkhead fitting. This one is for a mid mount loader
2017 Mitsubishi Outlander Sport SUV (A53424)
2017 Mitsubishi...
2006 Intellistrobe Automatic Flagger Assistance Device S/A Towabale Trailer (A52377)
2006 Intellistrobe...
2000 Trail King TK70SA-48.2 T/A 43 Ton Hydraulic Slide Axle Step Deck Trailer (A52377)
2000 Trail King...
2019 MACK PINNACLE P164T DAY CAB ROAD TRACTOR (A51406)
2019 MACK PINNACLE...
2019 CATERPILLAR CS44B SMOOTH DRUM ROLLER (A52705)
2019 CATERPILLAR...
