Not running off road diesel?
   / Not running off road diesel? #11
Luckily lots of stations here in north idaho carry off road diesel and ethanol free regular gas. No fuel cards or any of the foolishness.
   / Not running off road diesel? #12
And as for being same gas…. I wired turbine pumps in service stations for years. Same fuel. Theres an inline dye device that treats the off road. This also helps keep the fuel fresh as off road isnt used as much.
   / Not running off road diesel? #13
Yanmar 2210
I need to know, what do I need to mix in pump diesel?
Because the store down the road that sells off road diesel, there pump went down, and I'll need to run the car diesel, and I just got I injector pump rebuilt last year..
Thanks to Any who can help..
I've had more issues with off-road diesel fuel vs. truck stop diesel fuel.
The reason being, off-road fuel sits in the tanks so much longer and is not fresh like a frequent truck stop is. Old diesel in storage tanks in off-road and on-road is not a place to buy your diesel fuel.
Buy fresh (newer) diesel to keep your fuel system running its best.
   / Not running off road diesel? #14
Hmmm, how so?
What if a diesel vendor moves a lot of dyed fuel? Mine does. Never a problem in 12 years. I probably bought 20,000 gallons from him. Not one fuel related failure in 8 different off road diesel engines.
Don’t you think just the opposite could be true? I do.
100% correct.
   / Not running off road diesel? #15
Hmmm, how so?
100% correct.
I’m pretty convinced that the reason red diesel has a reputation for being dirty is people put it in nasty transfer tanks where the road fuel guys usually just drive to the station and pump it in eliminating that problem. It’s not uncommon for the pickups bed transfer tanks to have the nozzle just tossed in the bed collecting dirt which isn’t helping either.
   / Not running off road diesel? #16
My local station has both. No cards needed etc.. Only thing that has ever happened was when the cost of fuel went sky high. People was filling cans and then using it in Rd. vehicles. They wouldn't let me use Red gas cans. They had to be yellow. INKY. think about it. You can see the Red dye with a Yellow 5 Gal. can a mile away!!. This is true!!
   / Not running off road diesel? #17
They wouldn't let me use Red gas cans.They had to be yellow. This is true!!
Similar. I built a fuel caddy from a carwash soap barrel.
Cashier said it wasn't DOT-rated to carry fuel on the highway so forget it.
I had to go another mile and get road diesel. I put the caddy on Craigslist.
p1670121rfuelcaddy-jpg.265863
   / Not running off road diesel? #18
Costco is the only station near where i live that wont allow my unsecured (non-
permanent) 55 gal fuel tank to be filled.
   / Not running off road diesel? #19
You could buy a decal to put on the drum.
   / Not running off road diesel? #20
I get off road diesel at a station and nobody has ever said what or how to fill the containers. I even use one red 6 gal. container for diesel and nothing has ever been said. Credit card is used and on my way. I think the cashier is busy enough that they couldn't care less. I doubt they would call 911 about the color of your fuel can.
2023 yamaha (A55758)
Corn Grinder (A57454)
POWERTEC INDUSTRIAL BRUSHLESS P.M.A.C SERVO MOTOR (A58376)
POWERTEC...
2012 CATERPILLAR 914G2 WHEEL LOADER (A52709)
2012 CATERPILLAR...
DOOSAN G25KW GENERATOR (A58216)
DOOSAN G25KW...
(APPROX. 30) 2" X 4" X 20' X 1/4" THICK TUBING (A58375)
(APPROX. 30) 2" X...
