Not in the Operator's Manual B2410 Kubota Tractor
   / Not in the Operator's Manual B2410 Kubota Tractor #1
OBKB
Paris, Arkansas, USA
B2410
Not in the Operator\'s Manual B2410 Kubota Tractor
When the temprature gauge rises above normal and before the red mark I go to the shed and remove the debris from the radiator core with air. Sometimes I follow up with the water hose. Anyway I try to make it a habit to care for the air filter per the manual while the hood is up. I set the output air pressure on the compressor at 80psi.
   / Not in the Operator's Manual B2410 Kubota Tractor #2
Re: Not in the Operator\'s Manual B2410 Kubota Tractor
Best advice for air filter is never to touch it enough for it to become a habit. Ask your dealer to order you the BRAND NEW Deisel Engine Maintenance, Customer Edition. This is brand new, but they should have received info on it recently. It is very informative and comes with a manual and video or DVD. ANYONE with a diesel engine to maintain should have a copy.
The dealer I purchased my B2410 from allowed me to hang around in the shop while I was waiting on getting the seals replaced on the Back_Hoe out-riggers. Anyhow one of the gentlemen in the shop was tearing down what looked to be a fairly new three hole diesel. I asked what caused the engine to need the tear down. He said in a rather sarcastic way most likely a non maintained air filter. So I figure that when there is enough debris to cause the coolant temprature to rise the air filter is in need of an inspection also. Now I understand what you are saying about not touching the air filter. However it all has to do with the position of the air intake for the engine air cleaner on my tractor.
2017 FORD F-550 SERVICE TRUCK (A58214)
2017 FORD F-550...
1611 (A57192)
1611 (A57192)
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
PALLET OF JACKS AND JACK STANDS (A58214)
PALLET OF JACKS...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
