Tiller Nortrac tiller No manual
   / Nortrac tiller No manual #1
camanche
Whidbey Island, WA
MF40E Industrial
I got a 59" nortrac tiller delivered yesterday. Put it together today there was no manual and box was open (lost?) I think I got the tines on right but have no Idea what oil to put in gear box. Customer service is closed till tuesday. Here is a link to the tiller.
web page
Does any one have one of these. I guess I will have to wait till tuesday.
   / Nortrac tiller No manual #2
I can't imagine you could go wrong with 90w gear oil.
That is exactly what I was thinking /forums/images/graemlins/grin.gif
   / Nortrac tiller No manual #4
camanche, I would recommend 80W90 [non- foaming].
Also, if it has any of the Chinese lube in the gear box???... I would flush is out and then re-fill.
Still get your manual for future reference.
Ronald
   / Nortrac tiller No manual #5
On my Howard HR20 Rotavator, recommended is gear oil SAE 140 - 160. Either in geabox as in chain box drive.
When I bought it, I replaced oil with new SAE140, as I couldn't find heavier oil.
Thanks for the repiles I think I will flush and use the 85-90 till I get a manual seeing as I have some of that in my shop. Probably good to flush after the first 20 hrs of use any way.
Thanks again for prompt repiles. I hope this Chinese tiller likes rocks? /forums/images/graemlins/crazy.gif
   / Nortrac tiller No manual #7
I think you will be fine with the 85-90......like you said...it's in the shop.
Ronald
   / Nortrac tiller No manual #8
It will be fine with 85-90, especially as you have it /forums/images/graemlins/wink.gif
Just be careful that oil was unpacked, and don't have moisture in.
About flushing gearboxes, I run them a little, drain old oil out, fill with diesel fuel, run (free of load) and drain again. That procedure I'm doing two times.
Finally, drain out to last drop, set the drain plugs and fill with new oil.
That's my usual procedure on all new purchased used machines, and way how I did that on my fresh bought tiller (20y old).
SARLO MOWER (A55758)
2020 Ford F-250 4x4 Crew Cab Pickup Truck (A55973)
2020 Ford F-250...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
2006 Dewatering and Drying Centrifuge (A56857)
2006 Dewatering...
Case 1020 25ft Draper Head (A55315)
Case 1020 25ft...
2018 Deere 323E (A53317)
2018 Deere 323E...
