nortrac dozer need help with a repair
   / nortrac dozer need help with a repair #51
Thanks Bob, I appreciate your input. Yes, there's no power to the left side at all, like you said it goes around in circles real well! Sounds like I need to get wrenching. I'm in the process of ordering a parts manual (apparently there is no service manual) through circle G. So what is the ROPS and the "saddlebag"?:thumbsup:
Roll over protection structure - Wikipedia, the free encyclopedia And there is also FOPS:
Test FOPS - YouTube
"Saddlebag" is a colloquialism that refers to the compartments adjacent to the operators seat. The left one usually contains the battery, throttle control, and shuttle clutch shift selector lever and hydraulic reservoir - if so equipped.
Do you have steel or rubber tracks?
You might find some helpful hints here: https://www.facebook.com/yuchaidozer
   / nortrac dozer need help with a repair #52
I recently bought a nortrac nb3500 dozer and need help with figuring a few things out. First the breakaway tabs that are hooked to input shaft of trans are broken off or cut off. Does anyone know where to buy these? Second someone deleted the driver side hydraulic fluid tanks, so if anyone knows how or where or what I need to tie the 2 tanks back together that would be great.3rd does anyone know where I can get a manual for this thing? Thanks in Advance
   / nortrac dozer need help with a repair #53
For service and parts, try Tytan Tractors in Washington.
I believe your dozer is quite similar to the Tytan 406.
Other companies may have rebadged it too. When I was up there a couple of years ago, they were parting out one or two older dozers.
A bit of an odd company to deal with, but they may be able to help you.
   / nortrac dozer need help with a repair #54
Thanks for the information.
2008 Mazda CX9 SUV (A56859)
2008 Mazda CX9 SUV...
Sedan (A59231)
Sedan (A59231)
RAKE ATTACHMENT FOR MINI EXCAVATOR (A58214)
RAKE ATTACHMENT...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 Freightliner 122SD Day Cab Truck, VIN # 3AKJGND69FDGH1752 (A57453)
2015 Freightliner...
