Northern Tool Welding Helmet
   / Northern Tool Welding Helmet #1
Jarrett
Holden, Louisiana
Kubota L3130DT
Does anyone have this welding helmet from Northern Tool? It has a very quick response time and a very attractive price. Also, what are the pro's & con's you've experienced with a solar only welding helmet?
   / Northern Tool Welding Helmet #2
It sure got a lot of positive reviews. I have one of the $250 helmets, which has both solar and batteries, and I wouldn't rate it that high. It easts batteries, even when switched off.
Why not just buy it?
   / Northern Tool Welding Helmet #4
I have one of those helmets. It has worked great, with variable shade adjustments. I read somewhere that if they fail, it will fail to somewhere around a shade four. You can test them with a cigarette lighter. I usually look to the side of the helmet on the first arc just to make sure that it is working.
   / Northern Tool Welding Helmet #5
I squeeze an acetylene striker to test my helmet.
   / Northern Tool Welding Helmet #6
I don't own that particular model,but I have basically the same helmet from HF for three years.Just bought the battery operated "skull" model on Friday.I have a problem with the mess in my shop and figure that big red skull outta stand out when I misplace my helmet.I find it cheap enough to replace the whole thing when the lens gets messed up enough not to see through.
   / Northern Tool Welding Helmet #7
I have that helmet and I really like it. I was using it during the very hot summer months (95+ degrees outside in the shade) and I was looking almost straight down while welding and I noticed that my forehead was dripping saltwater onto the switches. The helmet did fail shortly thereafter but it was not a big surprise given the relationship between saltwater and printed circuit boards. The replacement has operated flawlessly since. I would not hesitate to buy one - you will enjoy it.
If you are in the heat like I was, either keep a slight angle or put a piece of tape over the switches.
   / Northern Tool Welding Helmet #8
I have the same helmet, it works good. I have had it for @ a year now.
The head gear is junk, I swapped out the head gear with better stuff and I am happy with it now.
   / Northern Tool Welding Helmet #9
I have one like that and used it for the first time last week and I really liked it. I was welding some fence panels on some gates and using a 135 mig, you would not believe how fast I finished each one. There was no raising the helmet or changing rods.
   / Northern Tool Welding Helmet #10
Don't know about that particular helmet, but I have one from Harbor Freight that is a "solar only" helmet. In response to that part of your question, I can only say that it's never failed to darken properly.
In fact, I find that I usually reach for the el-cheapo HF helmet instead of my considerably more expensive Miller XLix. (And if anyone asks why, I can't really give you an objective answer - I just like it better.)
2006 Kobelco SK210LC Hydraulic Excavator (A52377)
2006 Kobelco...
RYOBI 420V BRUSHLESS ELECTRIC 21" PUSH MOWER (A51248)
RYOBI 420V...
UNUSED CFG INDUSTRIAL MX50R EXCAVATOR (A51247)
UNUSED CFG...
2012 Dodge Grand Caravan Van (A51694)
2012 Dodge Grand...
PAIR OF 5' PIN ON FOLD UP RAMPS (A51247)
PAIR OF 5' PIN ON...
2009 Freightliner B2 School Bus (A51692)
2009 Freightliner...
