Northern Tool Sandblasters???
   / Northern Tool Sandblasters??? #11
Great points Mike! You can get silica-free "Black Blast" but you definitely need to screen that (not a bad idea anyway)and I like silica's cutting better, so the respirator is a must. I only have the cheap gloves and cheap hood, but it is indespensable! Also I line the lens with tranparancy for cheap replacement; they cloud up fast.
Yep, that's the Texas I was pondering myself! Looks better built than Northern unit. I'd think if they've been around as long the website says, parts shouldn't be an issue; of course you can pick-up a 38special valve for around $100 or a straight handle for less. Else, $50 more buys a simalar Brut; or $100 more gets one with "pull up" closure [no threads to contaminate]; much like mine, but my cheap butt searched till I found a "used once" unit with 38special, hood, gloves and spare parts for $200. /forums/images/graemlins/smile.gif
<font color="red"> Edit </font> If you like Northern, I think they have some ALC pressure units, that should be decent quality.
   / Northern Tool Sandblasters??? #12
I have the 40LB pressure type blaster from HF. Works fair on a 3 hp compressor for about 7-10 min, then you heave to wait for the compressor to catch up. By 7-10 min I need to unfog the hood lens anyway /forums/images/graemlins/smile.gif On my FIL's 5 HP unit it works pretty good, not like a big commercial unit, but not bad at all for the money. It needs about about 12 cfm @90 to work good. I use either regular sand or the :black beauty" slag stuff.
Ben
All . . . thanks for the replies, but it seems to me that there is a point at which this gets to be too expensive for me to consider. I don't use a compressor for very much now, I have always just sent my sandblasting "out" to be done in the past, so we have laws of dimishing returns coming into play since my needs are modest. I think I may try a larger compressor, I found an Ingersoll Rand unit that puts out MARGINALLY more air at DOUBLE the price of my current Craftsman unit but is a 2 stage unit so it should keep up a bit better IF I understand it correctly? But it is lower HP and has a smaller tank so it would probably run more frequently. Ingersoll Rand compressor And I may go for something like the Texas blaster that is pointed out earlier on the thread for sale on Ebay. Beyond that, I'd be better off just sending stuff out to be done.
I need to blast some parts of the Sno-Trac for that restoration. But it should not be full body panels, more like isolated parts. I'm looking at buying an old mechanical tobacco transplater and restoring that for use in planting veggies. Beyond that, I have no other needs until I buy another tractor for restoration, but the Sno-Trac will keep me busy for a while.
So now that my needs are more clearly laid out, do you think I am being realistic or should I skip the sandblaster idea?
   / Northern Tool Sandblasters??? #14
I got my pressure blasting toys when the wife was quoted $1000 just to have her horse trailer "dusted off." Ironically for the past 6 months that same 20cfm compressor has been used to fill a few tires and an occasional air tool [but I have toys waiting for blasting, so it'll be used plenty again]. So if you have an econimical source for blasting, that is perfect [not to mention keeping the sand out of every oriface on your body].
On the other hand, I don't think your plans are unrealistic. Just looking at the pictures, I'd go for the Texas over the one you first listed, but skim the web for a few more brands [TP, Brut, ALC, Clemco, about a half dozen more] and you may find something as good or better. Also, Ebay often has good ones that somebody used for one project or used once and didn't like the mess. Remember if the tank is decent, pressure blasters are dead simple. A couple ball valves. Some hose [though $2.50 a foot or something outrageous], and a shutoff valve; everything from $10 cheapos to $70 to $125 for something not disposable.
As far as the IR, you're not really getting any more or less compressor<font color="red"> output</font>, but for<font color="red"> much more of your money </font> [you're paying for the Name and probably a little more quality]. I don't think it is a 2 stage [it is 2 cylinder], but if so that means slightly better efficiency, much better at higher pressures. Always preferring longevity and despising dishonesty in advertising, I'd have to do the IR if they were the only two choices, but I just don't think you need the gains it offers.
The best I can say is go with a big tank [you already have the smaller compressor] and cheap pump [220V is more effecient]. Then you can at least get a feel for blasting [a couple minutes at a time], and if you decided you want more air latter, parallel in an Eaton pump and motor [don't forget a 30amp relay or a starter].
   / Northern Tool Sandblasters??? #15
Realized that for over $500 on the IR you could have an Eaton or something like it that would almost keep up with your blasting needs; for intermittant use I'd think you'd be happy with 14CFM @90psi [for tractor hoods or large things, you'll still wish for about 50-100% larger output].
Eaton
Good Luck
   / Northern Tool Sandblasters??? #16
When you get into things like tractor hood and other large items, you better have a good working knowledge of what you are blasting with, because it doesn't take very long for a sand blaster to render a larger piece useless because the blaster has warped and distorted it. I have seen many a good car ruined by an inexperienced sand blast operator that warped every panel to the point where the car looked like a giant wave after being painted.
   / Northern Tool Sandblasters??? #17
Ouch, Bob. I like Ingersoll-Rand products, and if you just have to have a portable compressor, and need it to run on 120 volt instead of 240, I guess that one is OK, but overpriced in my opinion. This Puma looks like what I had; much more capacity for a lower price.
   / Northern Tool Sandblasters??? #18
<font color="red"> The best I can say is go with a big tank [you already have the smaller compressor] and cheap pump [220V is more effecient]. </font> Note: I'm saying this for the situation afore mentioned....I still can't tolerate a salesman that hypes "peak HP" or tank size when I ask about continuous usable CFM @ XXpressure. /forums/images/graemlins/frown.gif
<font color="blue"> This Puma looks like what I had; much more capacity for a lower price </font>
Something like that is exactly what I had in mind, Bird! With only 2 exceptions I can think of [none listed here] everyone is outsourcing their pumps anyway (but there's still a huge range of quality). The pump and motor on that type of unit isn't what you'd want for much <font color="red">edit: like daily </font> continuous use or too much abuse, but I think it will get your blasting ambitions up & running just fine Bob.
I hated both my small compressor and my gravity blaster so bad that I did one tractor [and rented an extra 10cfm to supplement the 5cfm] then rarely used it in the last 10 years; oohh do I like the pressure unit and having the power behind it! /forums/images/graemlins/grin.gif
   / Northern Tool Sandblasters??? #19
</font><font color="blue" class="small">( The pump and motor on that type of unit isn't what you'd want for much edit: like daily continuous use or too much abuse )</font>
Chad, I was a little bit skeptical myself when I bought it, but I bought it from a company that I trusted because of a prior experience with them, and they told me they had some of those Pumas in places where they ran 18 hours a day (I'd never heard of a Puma compressor at the time). Now that company also makes some of their own compressors and the guy told me that the Puma "6 hp" motor was what they called an "imitation 6 hp". Sitting beside it was one of their own 80 gallon 2-stage 175 psi compressors with what he said was a "true 5 hp" motor that was at least twice the size of the motor on the Puma, and I could have bought one of those for about twice as much money.
Now my Puma didn't run really long hours at a time, but I was repairing/rebuilding mechanics' air tools at the time, so it was a rare day indeed when it wasn't used since I used the blow gun to dry parts that I took out of the parts washer, powered my Cyclone blaster cabinet with glass beads, powered my own air tools, including the sand blaster, occasionally the paint gun, and I even used a siphon type gun to spray insecticide at times and herbicide on the driveway, as well as using a long nozzle blow gun to "sweep" the shop floor frequently. I had three 50' hoses, one 15' hose, and two 10' hoses, so I could get all the way around the house, or anywhere in the house when I wanted to. I never worried about running it too long and never had a single problem with it.
   / Northern Tool Sandblasters??? #20
<font color="blue"> the guy told me that the Puma "6 hp" motor was what they called an "imitation 6 hp". </font>
Honest sales, now that's the type of people I'd buy something from! 18hours daily?! Wow....that's more in a year than I'd do in 25; sounds like it treated you well too. /forums/images/graemlins/cool.gif
Year: 2022 Make: Ford Model: F-150 Vehicle Type: Pickup Truck Mileage: 6,257 Plate: Body Type: 2 (A51692)
Year: 2022 Make...
2015 Ottawa Yard Spotter Truck - Cummins Diesel, Allison 6-Speed, Hydraulic Air Fifth Wheel (A52748)
2015 Ottawa Yard...
PICKUP TOOLBOX (A52472)
PICKUP TOOLBOX...
2008 MAGNUM TRAILER LIGHT TOWER TRAILER (A52472)
2008 MAGNUM...
NEW Mini Excavator Fixed Thumb Attachment (A53002)
NEW Mini Excavator...
2018 TAKEUCHI TL8 SKID STEER (A51246)
2018 TAKEUCHI TL8...
