Northern tool cut off saw
   / Northern tool cut off saw #1
milkie62
upstate NY
Kubota M6800,Ford 801,MF 65, Kubota L305
has anybody used the 14" Northern tool cutoff saw that uses the toothed blade ? been wondering on getting one for projects. Have a 12" abrasive wheel but it throws a lot of sparks.
   / Northern tool cut off saw #2
I have a 15" carbidetip blade for my stihl cut off saw great for demo cutting roots roofs etc. You have to have a big set of brass ones to use it .:eek: Little sketch.:drink:
   / Northern tool cut off saw #3
I don't have the Northern tool but another brand of the same type. I've had it for a few years and used it for different projects, some big and some small. It works just as advertised. There is no heat, only a spark or two at times and makes a clean cut. It also cuts faster than an abrasive saw.
I haven't used my abrasive saw since getting this one.
   / Northern tool cut off saw #4
I have one of those Ironton 14" saws. Works great. Tosses shavings all around. Faster than the abrasive cutting and tidy cuts as others have mentioned. I need to throw away the old abrasive saw.
   / Northern tool cut off saw #5
I have a different brand also. It is a great type of saw. The very next tool I bought after the dry-cut saw was a 36" magnetic sweeper. The saw throws chips all over so wear glasses AND a face shield.
It sure beats having all that dust in the air from an abrasive cut saw.
   / Northern tool cut off saw #6
Back in high school, I had a little Handler 130 and a 14" abrasive saw... hated the abrasive saw. Fast forward to adulthood, I purchased an Evolution Rage 14" a few years ago and never looked back. It's since been supplemented by a Dewalt 14" (nicer, more accurate saw), as well as the Klutch benchtop bandsaw. The carbide chop saws are a night and day difference over an abrasive saw, and very fast... however the bandsaw takes the take for cost per cut at a slight time disadvantage.
   / Northern tool cut off saw #7
I have the Evolution saw as well and love it. Probably the thing I like the most is you can take a half blade width cut off the end of your material. An abrasive would just walk off the end forcing you to use a grinder or something else.
Blades are a bit spendy but I'm still on my first one even though it has several teeth broken off, still cuts fine.
   / Northern tool cut off saw #8
I have an Evolution, but mine is a 10 inch sliding compound mitre saw. Really the only difference between it and my other miter saws is the low RPM's it runs at. In my mind the dry cut vs the abrasive, is like the plasma vs oxy/acetylene. Night and day in use. Perfect mitres.
   / Northern tool cut off saw #9
I have the pre-Irontron Northern Tool cut off saw. It has worked very well for almost five years. I expect the current model to be good as well.
Thanks for the responses and will watch for another sale.
2018 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A52577)
2018 FREIGHTLINER...
2018 Kia Soul Crossover SUV (A51694)
2018 Kia Soul...
NEW Wolverine 72'' Skid Steer Sickle Bar Mower (A53002)
NEW Wolverine 72''...
2015 ISUZU NPR 16FT BOX TRUCK (A52577)
2015 ISUZU NPR...
Redirective Crash Cushion Guardrail (A51692)
Redirective Crash...
2018 TAKEUCHI TL12V-2 SKID STEER (A51242)
2018 TAKEUCHI...
