Northern Tool and Equipment
   / Northern Tool and Equipment #11
Venturing a guess wouldn't be a good move since a pretty close fit is still not good enough. The slots are designed to work with the chuck and vary even within brands. My thought would be to buy a drill to be compatible with available bits or rent a bigger/w3tcompact/icons/cool.gif machine (less spin more hit) and get the job done quicker using less bits. Bear in mind, if an imported tool is purchased without a UL label, don't stand around in the rain or snow, you could get a shocking /w3tcompact/icons/shocked.gifsurprise!! Most of this work is outdoors! /w3tcompact/icons/smile.gif SteveV
   / Northern Tool and Equipment #12
Dave, This is one tool that I wouldn't buy cheap. I've had VERY BAD experiences with cheap hammer drills. I've burned up 4 cheap drills, just trying to drill RR ties and set concrete anchors. Then I bought a Milwaukie hammer drill. No problem with any job, and it has so much torque that it almost twists your wrist off if you don't have a good hold of it. With this type of HD use tool, it pays to get a good one. On the last cheap one that I burned up, I got so digusted that I threw it in the trash, even though it was still under warrenty. (I had just recieved it back from the factory repair shop after a long wait).
2018 Deere 323E (A53317)
2018 Deere 323E...
2013 International WorkStar 7400 4x4 Altec Bucket Truck (A55852)
2013 International...
2015 PCI MFG. SOLUTIONS 130 BBL STEEL VACUUM TRAILER (A53843)
2015 PCI MFG...
2017 Ram 1500 SLT Crew Cab Pickup Truck (A56858)
2017 Ram 1500 SLT...
2014 Nissan Altima S Sedan (A55853)
2014 Nissan Altima...
Mobile toilet with shower (A53424)
Mobile toilet with...
