noob with new 2520
   / noob with new 2520 #11
jdbower said:
Regarding the key, they aren't actually keys but more generic starting tools. I got two from my dealer, but since they're all the same I'd have no problem getting more if I lost them.
Wait, is this right? All the "keys" are the same? Hmmm...maybe THAT's why I didn't need to leave my key for the dealer when he came to transport my 2320 back to the shop. He said he "had a master key" but I had no idea that it meant "they're all the same."
It reminds me of the pre-1974 BMW motorcycles. All of them used a thing that looked like a nail with groves in it to turn the ignition on and off. Having one meant that you could start ANY BMW motorcycle from the 1940's to 1973.
   / noob with new 2520 #12
farmerhays said:
I haven't seen anyone mention it here, but you have a spin-knob valve for hydraulic flow directly below the seat. As you are sitting on the tractor see, look down between your legs and you will see the black knob.
You may have your valve set wide open, which I have found is too much for the backhoe, although I haven't found the loader to be as sensitive to valve adjustment. I close mine all the way (to shut off the hydraulics entirely) and then open it back up a half-turn. Play with the setting until the loader responds the way you expect.
I grew up on big tractors, and none of them have this little valve, so I have found it useful right from the get-go.
That knob is the "rate of drop" knob for the 3PH, all it does is control how fast hydraulic fliud escapes the internal rockshaft cylinder. It has no control over the speed of anything other than how fast the 3PH falls depending of the weight of the implement attached to it.
   / noob with new 2520 #13
Yup, that is correct, they are all the same!
2019 John Deere XUV560E Utility Cart (A53421)
2019 John Deere...
Case 950 8 Row Air Planter (A55301)
Case 950 8 Row Air...
2016 Ford F-250 4x4 Ext. Cab Pickup Truck (A55788)
2016 Ford F-250...
2019 FORD F550 XL SINGLE CAB TRUCK (A54756)
2019 FORD F550 XL...
2015 Chrysler 200 Sedan (A55758)
2015 Chrysler 200...
2012 Freightliner M2 112 Fuel and Lube Truck, VIN # 1FUGC5DV5CHBF7397 (A54865)
2012 Freightliner...
