Noob question - Mahindra 2538
   / Noob question - Mahindra 2538
I’m looking at Mobil 424, since I can get it locally and 5 gals costs roughly the same as 1 gal of Mahindra Universal Tractor fluid, which I have to drive around 80 miles to go get.
   / Noob question - Mahindra 2538 #12
The GL-4 80 or 90 is gear oil, which you don't use in the HST. It's for the front axle.
I have used Mobilfluid 424 and Duragard semi synthetic HST fluid in my Branson. The Branson dealer is also a Mahindra dealer and when I did my first change, they suggested Mahindra's HST fluid.
I think the 424 is now called Delvac and is available as TSC. I'd also use Chevron TDF 1000 if that is available locally.
It's THF, not TDF. Good fluid, all I use actually. Rotella Hydraulic fluid ain't bad either and TSC carries that. Hydrostats require hydraulic fluid not gear oil.
Redundant - deleted
   / Noob question - Mahindra 2538 #14
Folks,
I've never owned a tractor before, but was a pretty good shade tree machanic in my younger days. I recently retired from the military, bought 20 acres and inherited the tractor with the property. It has 209 hours and I just had the local Deere dealer replace all the filters, but HSTs are a new thing to me. Hydraulic oil looks a bit low and manual says I need API GL-4 #80 or #90 Mahindra Universal tractor fluid, but the closest Mahindra dealer is over an hour's drive the away - is there a hydraulic oil I can get from the local Tractor Supply or Deere dealer that I can use?
Sean
Copied and pasted from another thread...
Fifty Hour Fluid Change Questions Post #10
"GL-5 specifications meet and exceed GL-4. So acceptable non Mahindra branded fluids that can be used include:
Shell Donax TD
Citgo Transgard Tractor Hydraulic Fluid
Exxon Torque Fluid 56
Chevron 1000 THF
Mobil Fluid 424
Texaco THD Special
Shell Rotella HD
Lucas Universal Hydraulic"
   / Noob question - Mahindra 2538 #15
If I remember correctly, J20C is the universal spec for Tractor Universal Premium Hydraulic Oil. If the manual specs gear oil for the trans / HST it is in error.
   / Noob question - Mahindra 2538 #16
Chevron 1000 THF. Good stuff.
Napa should have it or can get it next day.
WYLIE MANUFACTURING GOOSENECK WATER TRAILER (A58216)
WYLIE...
20357 (A55758)
20357 (A55758)
2013 Cummins DSGAB 125kW Standby Diesel Generator (A56857)
2013 Cummins DSGAB...
Year: 2017 Make: Toyota Model: Camry Vehicle Type: Passenger Car Mileage: Plate: Body Type: 4 Door (A59231)
Year: 2017 Make...
4001 (A59228)
4001 (A59228)
2023 Sundowner Rancher Express 24FT Livestock Trailer - All-Aluminum Stock Hauler (A55302)
2023 Sundowner...
