Noisy Transmission ford 1720 SSS
   / Noisy Transmission ford 1720 SSS #1
Hazzmatte
Ford 1720
Hello everyone. New to the forum.
I have a ford 1720 SSS and when I pull up the lever to engage the four wheel drive I get a lot of trans noise - very loud in 4th gear-high range and not normal. The noise gets louder the faster I go. Full speed the trans sound like it screaming at me.
When I switch to medium or low range the noise seems to stop - or maybe its there but not noticeable.
When I switch back to 2wd it goes away and sounds normal.
Any idea where the problem might be?
   / Noisy Transmission ford 1720 SSS #2
Didnt think you were supposed to engage four wheel drive in high gear?
   / Noisy Transmission ford 1720 SSS #3
Do you have the correct size tires on it front and rear. If you do not it can cause the drive line to bind up on hard ground.What are you doing that you are in high range in 4x4. I would not recomend driving down the road in 4x4. Make sure the front drive shaft has plenty of grease if yours is greasable.
Bill
@Hooked
yes factory size tires, only run on grass. Makes noise in the mudd too.
Defiantly a mechanical problem and coming out of the trans case. Had it at the dealer for them to look at it and said it probably would cost 3k-4K to fix
   / Noisy Transmission ford 1720 SSS #5
Hazzmatte said:
@Hooked
That sounds crazy high! What all are they going to do or replace for that price? I understand transmission/differential/transfer case repairs can be intensive on labor time but that sounds way high. Again, it could be a fair asessment, but I am curious to know what all you are getting for that amount of loot?
   / Noisy Transmission ford 1720 SSS #6
Did anyone look at the front driveshaft cover? They sometimes get bent and contact the driveshaft. The shaft still turns in 2wd but might flex differently when not driving the wheels? Swag
Jim
UPDATE: Discovered that the slide gear on the pinion was damaged. Replacing the slide gear Fixed the problem. No more noise when in 4wd.
   / Noisy Transmission ford 1720 SSS #8
Fantastic! I was also going to comment on the fluid. Looks rather thick - not supposed to be gear oil!
2025 New/Unused LandHonor Massage Chair Sofa (A51573)
2025 New/Unused...
BAUMA LIGHT TX 12 LOT NUMBER 240 (A53084)
BAUMA LIGHT TX 12...
2025 New/Unused Wolverine Skid Steer Land Leveler (A51573)
2025 New/Unused...
2000 Thomas Built Saf-T-Liner MVP-ER Transit Passenger Bus (A51692)
2000 Thomas Built...
2009 IC Corporation PB105 Passenger Bus (A51692)
2009 IC...
