Noise level of Kubota RTV-X900
   / Noise level of Kubota RTV-X900 #1
aloha
Hawaii - Big Island
Kubota B7800 / Kubota RTV X900 / Scag Turf Tiger
I am to the point that I can justify buying a utility vehicle and am pretty well settled on the Kubota RTV-X900. My main question is how noisy are these in operation? The only dealer around does not stock these so I cannot hear for myself, and I found no discussions of this. I cannot run my tractor, a Kubota B-7800, for more than a few minutes without earplugs. If the diesel RTV is similarly noisy that could push me to something with a quieter gas engine. All comments will be most welcome. Thanks.
   / Noise level of Kubota RTV-X900 #2
My 2008 RTV is about half as noisy as my tractors or lawn mower. If I am operating it for anything more than a quick trip, I still use hearing protection. Once you lose your hearing, you can't get it back.
   / Noise level of Kubota RTV-X900 #3
Mine is pretty noisy but it doesn't bother me. I think most of it is just loose stuff vibrating like crap. When I first bought it, half the bolts were either loose and just about falling out. The right rear hinge no the bed gate did fall out!
   / Noise level of Kubota RTV-X900 #4
When considering, I drove both an RTV500 and a diesel RTV at the Kubota dealers. The diesel was quite a bit louder than the gas RTV500, which I bought. The gas RTV500 is quite a bit louder than my L3560 tractor. I wear ear muffs operating both.
   / Noise level of Kubota RTV-X900 #5
My X900 is a lot quieter than the Polaris Ranger I had previous to it. I think I measured it at 73 dB in the cab running at 12 mph. I can carry on a conversation in the cab. My RTV 400ci is a bit louder and it is gas. If I was to be driving my X900 constantly all day I would likely want to wear hearing protection, but although I use it all day, it is for short (1 mile or less) trips at a time. I have a top and rear window which helps cut the noise down. My B7800 is loud enough that i wear hearing protection when I use it, although it isn't too bad.
   / Noise level of Kubota RTV-X900 #6
The newer "X" models are quite a bit smoother/quieter, if you can believe it. I say that because they still won't win any awards.
I have an RTV-X1120D, and while it's noisy, I don't find noise to be an issue. I have a roof and windshield on mine, which seems to make it noisier inside the cab. I think it's noisiest at idle, and calms down once you get moving. At high speed it starts getting noisier again -- driveline and tire noise -- but not bad at all.
You won't really know without a test drive. It's hard to judge noise annoyance based on what other people think. What is OK to me might still drive you nuts. But anyhow, I don't have any real complaints with my RTV at all, and have never felt the noise to be a problem or out of line. It's a real handy little vehicle that is valuable for all sorts of work, and I always enjoy using it.
2018 Ariens Ikon 52in Zero Turn Commercial Mower (A56857)
2018 Ariens Ikon...
1995 TALBERT 50 TON LOWBOY TRAILER (A58214)
1995 TALBERT 50...
MARATHON 20KW GENERATOR (A55745)
MARATHON 20KW...
2022 Horizon Trailer (A55973)
2022 Horizon...
2003 Big Tex 10PI...
2022 Western Star W47005B Dump Truck, VIN: 5KKHAXDV6NPNJ0431, Detroit Turbo Diesel Engine, Tandem (A59076)
2022 Western Star...
