Noise in the right rear of my 990
   / Noise in the right rear of my 990 #1
gizmo
Jonesboro, GA
2002 JD990
Do any of you 990 owners hear a bumping noise in the rear of your tractor near the hydraulic pumps. I'm getting this primarily at low RPMs. I've also experienced a couple of occasions where the power steering stuttered with the FEL fully loaded. I'm getting concerned that I may have some pump issues.
   / Noise in the right rear of my 990 #2
I *think* the pumps are mounted on the left side of the engine, not at the rear. My 990 has a fairly pronounced knocking at idle which is a bit more audible at the rear. In my case I believe it's just normal diesel knock which seems louder at the rear of the tractor probably because it is being transmitted through the frame and transmission and the exhaust noise is lower at the rear and so doesn't mask the knock so much there. Also, I sometimes hear a much louder knock which after a bit of searching turned out to be the drawbar rattling in sync with the diesel knock. Just moving the drawbar a bit or putting my foot on it quiets it down. Check the drawbar, 3pt arms, etc. Maybe it's just something rattling like my drawbar.
In any event, a fairly pronounced knock at low rpms is pretty normal for most diesels. As far as the power steering stuttering, I'm not sure ...
Just as a point of interest, apparently a lot of that characteristic diesel knock actually comes from the injection pump itself, not just the firing of the cylinders. My cousin has his heavy duty mechanic ticket (among others) and he said when he was in school they had an injection pump hooked up and being turned with an electric motor. It was just pumping fuel through injectors into a bucket or something and he said it sounded exactly like a real engine running, and just about as loud.
Steel Work Bench 24" x 60" w/6" Irwin Vise (NO CONTENTS) (A59076)
Steel Work Bench...
1993 Ford F-250 (A56858)
1993 Ford F-250...
LOT: (2) Gear & Pulley Puller Sets (A59076)
LOT: (2) Gear &...
Steel Storage Cabinet w/Contents, 67" W x 24" D x 96" H (A59076)
Steel Storage...
2018 Ford F-350 Crew Cab Service Truck (A56858)
2018 Ford F-350...
METAL SHELVING & COOLERS (A58374)
METAL SHELVING &...
