Noise in FEL
   / Noise in FEL #1
GaryK
NC
JD 4100 HST
Last week I did about 8 hrs of heavy FEL work with my 4100 HST and all was fine. I had it off for a few days and reinstalled it to again do some moving of gravel. It was then that I would hear a popping or light clunking sound from the front of the tractor when I had a full bucket and was moving. It sounded like it was coming from the front right but its hard to hear with the machine running. It went away after a while. I checked for loose bolts etc at the site and later at home even went so far as to take out the driveshaft to the front 4wd, thought maybe a bad u-joint. All was well. I double checked all bolts etc on the FEL and frame, even the front wheels. Found everything OK. The next time I used the FEL, it again made the noise a few times. All I can think of that I got some air in the system somehow and that's what is making the noise when I put a load on the FEL. Any ideas? /forums/images/graemlins/confused.gif
   / Noise in FEL #2
Although it may sound hydraulic, it might be a bearing that need a little grease. My BH made some sounds similar to what you described and grease did the trick. Just a thought.
   / Noise in FEL #3
I have heard the same noise and the Dealer has come up with nothing. It sounds to me like a hydraulic leak under pressure but I can't find anything.
   / Noise in FEL #4
Try removing it an reinstalling again. It may be slipping a bit on the mount when you reach maximum height. Try having someone stand on the side while you are operating it.
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
2008 Featherlite Portable Office Command Center T/A Trailer with Wacker Neuson G50 Towable Genera... (A56858)
2008 Featherlite...
excavator trenching bucket- one bucket per lot (A56435)
excavator...
Case skid steer wheels and tires (A56435)
Case skid steer...
20 X 20 CAR PORT (A58214)
20 X 20 CAR PORT...
Landoll Lowboy Trailer (A56435)
Landoll Lowboy...
