Noise in FEL
   / Noise in FEL #1
GaryK
NC
JD 4100 HST
Last week I did about 8 hrs of heavy FEL work with my 4100 HST and all was fine. I had it off for a few days and reinstalled it to again do some moving of gravel. It was then that I would hear a popping or light clunking sound from the front of the tractor when I had a full bucket and was moving. It sounded like it was coming from the front right but its hard to hear with the machine running. It went away after a while. I checked for loose bolts etc at the site and later at home even went so far as to take out the driveshaft to the front 4wd, thought maybe a bad u-joint. All was well. I double checked all bolts etc on the FEL and frame, even the front wheels. Found everything OK. The next time I used the FEL, it again made the noise a few times. All I can think of that I got some air in the system somehow and that's what is making the noise when I put a load on the FEL. Any ideas? /forums/images/graemlins/confused.gif
   / Noise in FEL #2
Although it may sound hydraulic, it might be a bearing that need a little grease. My BH made some sounds similar to what you described and grease did the trick. Just a thought.
   / Noise in FEL #3
I have heard the same noise and the Dealer has come up with nothing. It sounds to me like a hydraulic leak under pressure but I can't find anything.
   / Noise in FEL #4
Try removing it an reinstalling again. It may be slipping a bit on the mount when you reach maximum height. Try having someone stand on the side while you are operating it.
3001 (A51691)
3001 (A51691)
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A52748)
80in HD Tooth...
2019 Bobcat S595 Skidloader (RIDE AND DRIVE) (A50774)
2019 Bobcat S595...
2017 JLG 10054 10,000LB 4x4 Rough Terrain Telehandler (A50322)
2017 JLG 10054...
2015 FORD F-250 XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250 XL...
2013 Chevrolet Equinox LTZ AWD SUV (A50324)
2013 Chevrolet...
