Noise in FEL
   / Noise in FEL #1
robbyr
Veteran Member
western east central texas
ford and mahindra
Mahindra 4500 makes a noise when tilting the forks up and seems to be weaker than it should. Raising the loader is not an issue only when tilting (such as a round bale). I have not noticed any oil that has leaked. Awaiting your expert opinions.
   / Noise in FEL #3
Do a pressure test, could be alot of diffrent things from oil level,condition to a weak relief, pump to grease. CJ
   / Noise in FEL #4
When the tilt up lever is held, the cyl is at the end of travel and the FEL valve will go into relief.
If trying to lift a heavy load the relief might sound off.
ALLEN TRUSS SCREED (A53843)
ALLEN TRUSS SCREED...
SAND BLASTING CABINET (A53843)
SAND BLASTING...
2015 Kia Cadenza Sedan (A53424)
2015 Kia Cadenza...
2017 FREIGHTLINER M2 S/A SWEEPER TRUCK (A51406)
2017 FREIGHTLINER...
2019 FORD F-150 XL SINGLE CAB TRUCK (A51406)
2019 FORD F-150 XL...
